20 Most Recent JVC AV-27980 27" TV Questions & Answers
I have a 20 yr
You have lost vertical output, its most likely a transistor that has failed
2/9/2018 9:16:11 PM • JVC AV-27980 27"... • Answered on Feb 09, 2018
manual
Sound but no picture
replace C960 1000MF/35VOLT electrolytic cap
it only has 2 legs and easy to replace
9/4/2009 2:37:29 PM • JVC AV-27980 27"... • Answered on Sep 04, 2009
No power
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Could be several things- a 15 cent fuse, some solder joints that fail due to expansion and contraction of the circuit boards. Hard to say. Look for parts that look or smell burnt, might help you narrow it down. Good luck
7/6/2008 4:21:09 AM • JVC AV-27980 27"... • Answered on Jul 06, 2008
How do I identify the reason why my JVC LT32C672 TV has lost the video output. (Red LED flashes on power up)
Unless you have electronic schooling and the equipment don't attempt to fix it yourself, it's a guessing game as far as what board, backlights or panel is causing the issue unless you have equipment, knowledge and service manual recycle it.
11/28/2022 3:47:01 AM • JVC Televison &... • Answered 12 hours ago
What is the code of JVC LT-32n33oA 32 inch please?
Question edited for clarity. That wasn't a 'serial number', it is the model number. What sort of 'code', universal remote code? Read this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/10/2022 10:29:48 PM • JVC Televison &... • Answered on Nov 10, 2022
5answers
How do i download Spotify to my jvc smart tv
I know the way for TCL Smart TV.you can install Spotify channel on TCL Smart TV via Roku Streaming Player or use the Spotify Music Converter from Tunelf to remove DRM protection from Spotify music and make them playable on any other device or platform.
11/10/2022 11:38:31 AM • JVC Televison &... • Answered on Nov 10, 2022
I have a 1080p jvc projection tv and I broke the bulb door safety switch. Can I bypass it so my tv will power on?
Hi Kyle, It isn't really recommended to bypass any of the safety switches in the TV. Maybe there is some other switch you can buy and install on the TV. What is the model number on the TV?
11/9/2022 12:42:05 AM • JVC Televison &... • Answered on Nov 09, 2022
JVC model DR-MV78BU DVD/VCR Combo Recorder does not recognize blank discs or a regular movie disc?
Hi, Please make sure that the discs do not have scratches . Then, you can clean any lens that the jvc machine uses to read your disc. Afterwards, you can attempt to play the discs again. If this does not work, please factory reset your device before attempting again. Otherwise, I think you might need to have the device repaired or potentially replaced. Thank you.
10/26/2022 5:25:06 PM • JVC Televison &... • Answered on Oct 26, 2022
My JVC us s59 keeps shutting down help
bad power supply
10/19/2022 3:40:11 AM • JVC Televison &... • Answered on Oct 19, 2022
2answers
JVC smart Tv, stock in android boot up logo, I am a new practising technician, can you help?
Unplug the JVC from the power outlet for 10 seconds. Plug the JVC TV back into the power outlet. Hold down both the "Menu" and "Volume Down (-)" buttons for another 10 seconds. Just before releasing these buttons, press and hold the "Power" button.
10/10/2022 9:55:04 AM • JVC Televison &... • Answered on Oct 10, 2022
3answers
JVC DVD player has no color
I need to know how the DVD player is hooked up in the back. Are you using HDMI, component or composite cables?
9/17/2022 4:58:33 AM • JVC Televison &... • Answered on Sep 17, 2022
The light on the bottom of my JVC tv isn't on and the tv itself won't turn on what do I do?
Two boards can cause the set to be dead, (power and main) considering this was storm related there is a better chance of it being power board failure, however static from lightning can come in the antenna or cable input if you use either of those. If you're using HDMI it's most likely going to be the power board.
7/31/2022 10:48:00 PM • JVC Televison &... • Answered on Jul 31, 2022
Hi my JVC LT-32DG20J won't turn on since connecting a new device into HDMI2 port, I've tried unplugging and that worked before but it doesn't even go into standby now.
Most likely you've damaged your main board from too large a load to the HDMI port.
7/25/2022 10:12:41 PM • JVC Televison &... • Answered on Jul 25, 2022
My JVC LT-40N555 television turns On then Off immediately. How do I fix it please?
Question edited for clarity and capitalization. Two questions made into one, duplicate Deleted. Refresh the page to see your question published. Check out the video https://www.google.com/search?q=JVC+LT-40N555+television+turns+On+then+Off ..
7/3/2022 3:38:07 PM • JVC Televison &... • Answered on Jul 03, 2022
Hi everyone I have a JVC Smart cloud tv LT-55N776A it can't play anything on showmax but only the trailers and there's no sound also..do you know what I can do to fix this issue?
Showmax is a 'Subscription on Demand' station, so you need to set up an account and they need your credit card details. You are currently in 'Preview Mode'. R99 per month. Register 5 devices, watch on 2 at the same time. Showmax Mobile. R39 per month.
Showmax
https://www.showmax.com Showmax is an online video entertainment service that offers unlimited series, movies, Showmax Originals, kids' shows, sport and more.
Home - Showmax
Search - Movies - Series - Real Housewives - The River - Gomora
Movies
All genres. Comedy. Crime & Mystery. Documentary. Drama ...
Series
All genres. Action. Actuality & Talk. Biography. Comedy. Crime ...
Watch your favourite local shows
Download to watch offline on your mobile or tablet with the ...
6/3/2022 1:47:00 AM • JVC Televison &... • Answered on Jun 03, 2022
JVC AV-27980 27" TV Logo
5 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
20 yr
  • Televison & Video
