20 Most Recent JVC AV-27920 27" TV Questions & Answers
manual
I have a jvc modle av-27920 that will not come on
This model should be covered by the Howard Sams Photofacts---you can buy one for it online with the model number--many large library's have them in archive as well.3 burnt means a problem in that area which is why you want the schematic as well.
11/5/2012 4:27:51 PM • JVC AV-27920 27"... • Answered on Nov 05, 2012
While watching tv I touch something on the remote
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
9/15/2011 4:27:49 PM • JVC AV-27920 27"... • Answered on Sep 15, 2011
My tv power is on but picture does not show only
hi
you have a shut down problem cause by a defective power suply that probably goes to high and activate a x ray or fail safe potection
9/29/2010 1:01:05 AM • JVC AV-27920 27"... • Answered on Sep 29, 2010
I need unlock code for jvc tv model # av27920
Try zero in the V chip menu
1/26/2010 11:39:21 PM • JVC AV-27920 27"... • Answered on Jan 26, 2010
2answers
JVC AV-27920 white horizontal lines on top of the screen
YES THERE ARE 3 CAPS. 2 ARE SMALL ONE LARGE IN THE VERTICAL CIRCUIT. 1 OR 2.2 uF AND A 1000uF. ALL ARE VERY CLOSE TO THE VERT. IC AND YOKE PLUG. PHYSICAL EXAMINATION SHOULD SHOW WHICH ONES DRIED OUT AS THE HEAT SHRINK WRAPPING AROUND THEM PEALS UP. ALSO WHEN YOU UNSOLDER IT YOU MIGHT SMELL "STINKY FISH" AS THE ORGANIC ACID INSIDE IS LEAKING OUT THE BOTTOM. LOOK FOR BROWN OOZE ON THE LEGS ALSO.
1/11/2010 1:37:05 AM • JVC AV-27920 27"... • Answered on Jan 11, 2010
My tv power light blinks when turning on the tv
check the power supply ( switched mode) if its giving an ht voltage to line transformer for supplying of small voltages to bais the tv semi conductors
okay
1/4/2010 9:33:19 PM • JVC AV-27920 27"... • Answered on Jan 04, 2010
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
9/13/2009 8:48:23 AM • JVC AV-27920 27"... • Answered on Sep 13, 2009
The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
3/24/2009 6:06:16 PM • JVC AV-27920 27"... • Answered on Mar 24, 2009
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
3/24/2009 6:02:35 PM • JVC AV-27920 27"... • Answered on Mar 24, 2009
Top of creeen rolls over and back down from the top about 3"
There is a capacitor in the vertical circuit that has significantly changed value causing this. If you are familiar with these units, look for a capacitor with the value of around 100ufd that is part of the vertical circuit and change it. That should resolve it. If you bring this to a shop, expect a parts cost up to $10.
Dan
3/17/2009 11:12:36 AM • JVC AV-27920 27"... • Answered on Mar 17, 2009
My JVC LT-40N555 television turns On then Off immediately. How do I fix it please?
Question edited for clarity and capitalization. Two questions made into one, duplicate Deleted. Refresh the page to see your question published. Check out the video https://www.google.com/search?q=JVC+LT-40N555+television+turns+On+then+Off ..
7/14/2024 3:55:00 AM • JVC Televison &... • Answered on Jul 14, 2024
JVC - DX5 Mini DV/HDD/DVD player recorder.
if the tray is dead, that means at least the power supply inside is dead in this nice old DVD DECK , made 2005 or older, near 2 decades old now, the manual is here free (1st google hit) http://resources.jvc.com/Resources/00/00/93/YD078ien.pdf this deck is old. so old no HDMI outputputs at all, just raw video/audio I see 3 possible problems (at least) the AC cord is not connected to the correct power source, or connect to power strip and it is dead. try direct wall connections AC 120vac if that is what it is. NO country told. 2: the DECK has bad DC power regulators inside 3: the Deck has a jammed up, tray, or disk inside has label falling off and jamming it up or kids put 3 DVD discs inside at once, common with kids. or worse, there is always that, look inside see all that stuff to fail. yes. it needs service, find some (a shop that does this ) and try that.?
6/30/2024 12:43:40 PM • JVC Televison &... • Answered on Jun 30, 2024
JVC Smart Television. It is showing no picture for DSTV, only sound?
Question edited for clarity and toss in some CAPS. JVC are known for this.
My JVC smart TV is stuck on a screen where it just shows ...
JustAnswer https://www.justanswer.com > TV Problems Sep 12, 2020 - My JVC smart TV is stuck on a screen where it just shows JVC Smart Tv and when I press source on the remote on any. Technician's Assistant: ...
How to fix a JVC TV that turns on and then loads but does ...
Quora https://www.quora.com > How-do-I-fix-a-JVC-TV-that-... Mar 23, 2020 - Unplug the JVC from the power outlet for 10 seconds. Plug the JVC TV back into the power outlet. Hold down both the "Menu" and "Volume Down (-)" ... 5 answers ยท If your JVC TV turns on but doesn't display any pictures, there are a few troubleshooting steps ... How to fix a JVC TV that when I switch it on, it just ... 3 answers Nov 7, 2021 Can someone help my JVC smart TV? After I have ... 2 answers Dec 16, 2022 Why is there no picture on a JVC LT49N775 TV but ... 1 answer Feb 25, 2022 What should I do if my TV screen is black but there ... 10 answers Sep 1, 2015 More results from www.quora.com ..
4/28/2024 6:51:47 PM • JVC Televison &... • Answered on Apr 28, 2024
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus Chunghop not chungCHOP :>D JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > chunghop-univer... Jul 25, 2019 - CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
3/20/2024 5:38:12 PM • JVC Televison &... • Answered on Mar 20, 2024
2answers
My jvc smart tv is not passing the android logo how do i fix
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
3/17/2024 3:32:51 AM • JVC Televison &... • Answered on Mar 17, 2024
JVC AV-27920 27" TV Logo
Popular Tags
19 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc modle av 27920 will not come
  • Televison & Video
