20 Most Recent JVC AV-36150 36" TV Questions & Answers
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - [email protected] - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place.......
JVC AV-36150 36"... | Answered on Apr 14, 2011
Hi
You seem to have bad solder joints.
If you are handy with a soldering iron you can take off the back cover and knock around the circuit(using something non conductive , i.e a wooden salad spoon) to locate the area of the problem.
Start by following the speakers wires to the connector(s) on the circuit board and the audio output i.c should be near by and mounted on a heathsink, thats the general area where you might find bad solders, you may have to do a bunch of them before you get to it as they are not allways apparent.
Hope this will help good luck
JVC AV-36150 36"... | Answered on Dec 15, 2009
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
JVC AV-36150 36"... | Answered on Nov 03, 2009
There can be many issues related to the problem 1. the cables are not fixed correctly some times we dont pay attention and there is a problem. Try to increase the volume using the remote? Leave it on maximum.also try using the digital out instead. 2. also there could be a fault resistance,in your av receiver/or dreambox!please check,the conection cable,replace,it,and try other sources,to find out,what could makes the problem.
Please do check it ur self.. and let us know. Good Night and good luck.!!
JVC AV-36150 36"... | Answered on Aug 17, 2009
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
JVC AV-36150 36"... | Answered on Jul 10, 2009
Is it possible that the input to the TV is still good including cables and cable box or anything? If another TV works from the same input then it may be the TV settings like AV/video rather than TV channels. Check all this out. I hope it is something simple as that. Good Luck.
JVC AV-36150 36"... | Answered on Sep 22, 2008
yes there should be a samll board that has the supply module on it it's the one with the direct link to the chord this board has a solid state module. if it doesn't on this model it should be the one on the main board that is directly linked to the small board.
JVC AV-36150 36"... | Answered on Sep 02, 2008
chances are it fried the power supply module. you can get the part at a repair store mostimes the module just plugs in the main board, but it too could be a soldered connection........please rate this...
Use the App Search feature.
JVC Televison &... | Answered 3 days ago
Without a remote control, you can't.
JVC Televison &... | Answered on Jan 13, 2020
Google
make model reset
Press the "MENU" button on the remote to display the main menu. Highlight the "Setup" option using the up or down arrow buttons. Press the right arrow or "ENTER" button to access the Setup menu. Scroll down to "RESET" and press right arrow or "ENTER."
What are some ways to reset a JVC TV? - Quora
https://www.quora.com > What-are-some-ways-to-reset-a-JVC-TV
JVC Televison &... | Answered on Dec 25, 2019
JVC AV-36150 36" TV Logo
Popular Tags
11 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
black square in middle screen
  • Televison & Video
