20 Most Recent
Zizzle Handheld Pirates Of The Caribbean Lcd Movie Game Questions & Answers
Zizzle "Hooked on Phonics" sound
Hi cknight187,
You may try the troubleshooting below that can be done to get the sound to work again with the Zizzle "Hooke on Phonics".
1.
Use the steps below to change the sound card to something other than the Game Compatible setting.
- Click on Start, Settings, and Control Panel
- Double click on Multimedia (or Sounds and Multimedia in Windows Me, or Sounds and Audio Devices in XP)
- Under the Playback section, look for the Preferred Device.
- Under Preferred Device, click on the arrow pointing down and select a device other than Game Compatible..
- Click on the Apply button, then the Ok button.
2.
If that does not correct the issue, you can bypass Microsoft DirectSound, and play audio directly through your sound card.
- Click Start, and then Run.
- Under DirectX features, you will see the Hardware Sound Acceleration Level.
- Move the slider bar to the left or right until it says Basic acceleration and click Exit.
3.
If you are still experiencing problems, check the following:- Check that your speakers are turned on and connected to your computer.
- You can verify that your sound system is working by playing any audio file.
- Make sure you've closed any other programs that use audio, such as
RealAudio,
WinAmp, or
Napster.
- If the audio still doesn't work properly, update the drivers for your audio card from the manufacturer's Web site.
Hope it helps.
Thank you for using Fixya.
4/11/2011 7:47:10 AM •
Zizzle Toys
Answered
on Apr 11, 2011
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
