20 Most Recent Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Questions & Answers
If you contact the manufacturer, they should be able to provide this needed default password. Best Wishes
Brother Wireless... | Answered on Mar 23, 2020
I had the same problem. I blew the dust out of the printer, cleaned the rollers, and checked for updates....still would jam in duplex mode. I finally got a bright flashlight and watched the paper through the crack between the back cover and case and discovered the paper was getting stuck under the paper tray. I turned the printer on its front and discovered there was a partial sheet of paper stuck in the paper path. It was difficult to get to but when I removed it, the printer started working correctly again in duplex mode. Hope this helps some of you with the same problem.
Brother Wireless... | Answered on Sep 11, 2019
Auto detect if it is a new original toner.
Brother Wireless... | Answered on Dec 06, 2017
go into printer properties and set the colour as default.
normally when you go to print something there is a tab section that will get you there before you actually press print
Brother Wireless... | Answered on May 24, 2015
Depends on OS. Generally speaking reinstall all software including drivers after uninstalling them
ONLY use the supplied drivers NOT windows drivers!
Mac OS X will sort itself out.
Brother Office... | Answered 3 days ago
The 4 blinking lights means that the fuser either got too hot or didn't heat in the expected time or there was a mechanical problem. See https://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hll2320d_us_as&ftype3=1968&faqid=faq00000170_025 . The first step of the diagnostic is to turn off the printer and wait for a bit. Turn it back on but leave the unit idle for at least 15 minutes. If the printer is under warranty, contact Brother.
Otherwise, if the error repeats, you'll need to check whether a thermistor is faulty, the wiring has a problem or if one of the PCBs (control board) is faulty. Check the wiring harnesses for broken conductors and the connections for corrosion. If the fuser unit gets hot without getting excessively hot, then one of the thermistors isn't detecting the temperature or the message didn't get to the PCB. If the fuser unit stays cool or gets way too hot, then the fuser heating element (or the wiring between that part and the PCB) is a likely culprit. A service manual is available here: https://printcopy.info/?mod=erc&brand=Brother&model=HL-L2320D&page=3 .
I hope this helps.
Brother Office... | Answered on Jul 29, 2020
  • Launch the Start Menu.
  • Go to the "Control Panel".
  • Even you can use the shortcut keys i.e. Windows key + X.
  • "Hardware and Sound" >>>> "Devices and Printers"
  • Select and Right-click on "Brother Printer" option.
  • Click on "Printer Properties" option.
  • A new tab will open on your desktop's screen, and you will find the "Printer Properties" option.
  • Select the "Ports" Tab
  • Scroll down and check-mark the "Standard TCP/IP port" and select "Configure Port".
  • Unmark "SNMP Status Enabled"
  • Tap "OK" and Click on "Apply" Button.
  • Reboot or restart your system and see whether your Brother printer is working or not.
    OR
  • Go to "Control Panel".
  • Click on "Hardware and Sound" option.
  • Select the "Devices and Printers" option.
  • Right-click on the Brother printer and tap on the "Remove Device" option.
  • Tap "Yes" to confirm. This will remove the current selected Brother Printer.
  • Restart your computer system once and during the restart unplugs your Brother printer.
  • As it gets reboot/restart successfully, plug in the Brother Printer device and reinstall the Brother Printer drivers.
  • After the successful completion of printer driver installation, restart your PC once again.
Brother Office... | Answered on Jul 22, 2020
It is very common to find Brother Printer in Error State Windows 10 with any Printer, the equivalent is the problem with the Brother Printers and scanners. People also face error due to some reasons. Certain error codes indicate some particular problems with your printer. One such difficulty is with Brother Printer Error State Problem, the error popups on-screen, and weak your printer from working.
Solutions that fix Brother Printer In Error State Windows 10:-
1.ReStart Your Brother Printer
2. Practice the Parallel Port
3. Combine Printer Via Ethernet wire
4. Review and Re-connect to Wi-fi Network
FULL BLOG- Brother Printer In Error State Windows 10
Brother Office... | Answered on Jul 21, 2020
To set up your Brother machine on a wireless network:
  1. Connect the power cord to your Brother machine and then connect it to an electrical socket.
    Turn your Brother machine on.
  2. Press Menu button on the machine's control panel.
  3. Press the Up or Down arrow key to select Network and press OK.
  4. Press the Up or Down arrow key to select WLAN and press OK.
    (This step may not apply to all machines.)
  5. Press the Up or Down arrow key to select Setup Wizard and press OK.
  6. When WLAN Enable? appears, select Yes to enable the wireless network.
    This will start the wireless setup wizard.
  7. The machine will search for your network and display a list of available Network Names (SSIDs).
    When a list of SSIDs appears, press the Up or Down arrow keys to select the SSID you wrote down earlier, and then press OK.
  8. Do one of the following:
    • If using an authentication and encryption method that requires the Network Key (Password)
      Enter the Network Key, then press OK to apply your settings. Select Yes to apply the settings.
    • If your authentication method is Open System and your encryption mode is None
      Go to the next step.
Brother Office... | Answered on Jul 20, 2020
Follow the software installation procedure and fault finding.
Brother Office... | Answered on Jul 17, 2020
Check that Your printer is properly connected and there is ink in cartridge. Also Check for the paper jam. If every think fine and still its showing same error message read blog Printer in error state.
Brother Office... | Answered on Jul 16, 2020
Re boot computer, router and printer.
Brother Office... | Answered on Jul 15, 2020
Download the software and follow the on screen prompts.
Brother Office... | Answered on Jul 11, 2020
See Step 15 in online instructions at the link below:
http://www.shareyourrepair.com/2015/08/how-to-fix-brother-mfc-8950-replace-parts-pf-kit-1-error.html
Step 15: Reset the PF Kit 1 Counter This will clear the "Replace Parts PF Kit 1" error that keeps coming up.
Step 15a: From the main menu simultaneously press both the 3 and 9 keys once.
You must access the secret reset menu to do this. If you don't time it correctly you will set the number of copies. If you do that just press the Stop/Exit button and try again. You DO NOT hold the keys down, just simultaneously press them once:
Simultaneously press the 3 and 9 buttonsIf you do it correctly, you will see the reset menu on the display:
The Secret Reset Menu
Step 15b: Tap "PF Kit1" on the screen.
Tap PF Kit1It will double check and ask you if you want to "Reset PF Kit1?" Tap "Yes."
Tap YesIt should then say "Accepted" to let you know that the counter has been reset:
After tapping yes it will say "Accepted"To get out of the Reset Menu press the Stop/Exit button:
Press the Stop/Exit button to get out of the Reset Menu
Brother Office... | Answered on Jun 30, 2020
Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Logo
15 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
default passwords
  • Office Equipment & Supplies
