20 Most Recent JVC AV-32S575 32" TV Questions & Answers
Are you sure this is the correct model (one listed here) above?
line is top top bottom or left to right and black?
JVC AV-32S575... | Answered on Dec 18, 2012
What is on the screen?
If this model has that it will be one of the rear sets of component jacks which will be marked as HD or 1080-----use the input button on the remote or the set if there to change to the correct input on the set. Hookup and select correct input.
JVC AV-32S575... | Answered on Dec 04, 2012
013/ 054/ 055/ 060/ 065/ 067/ 089
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
JVC AV-32S575... | Answered on Aug 20, 2012
Your power supply has failed.
JVC AV-32S575... | Answered on Apr 27, 2011
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
JVC AV-32S575... | Answered on Mar 18, 2011
shut off CC.
JVC AV-32S575... | Answered on Mar 04, 2011
Unless you paid for world wide warranty, the TV is only under warranty in Kuwait.
If you contact JVC.com and find a service centre near you, they will explain the system.
JVC AV-32S575... | Answered on Feb 21, 2011
Hello
Your TV is not getting any signal at all to process, or the tuner inside your TV is faulty. Blue back screen comes, when there is no signal to any of its input or faulty tuner. Just connect the tV with any other video source, like VCR or DVD , connected to its AV terminals and set the tV to take input AV, and check whether picutre comes in or not. If picture comes with AV connection, make sure that your tVs tuner is faulty and should be replaced. If no picutre comes with AV connections too, the Chroma Ic insie your TV is faulty, and should be replaced. OK.
JVC AV-32S575... | Answered on Feb 17, 2011
Sorry ur tv is an analog tv set u will not able to get HD on to an anolag tv set.Analog tv dosen't have the abilities to produced a high enough resolution to get a HDTV modes.U want HDTV modes,must have a LCD that have 1080i or 1080p or plama tv.
JVC AV-32S575... | Answered on Jan 17, 2011
It is an indication of faulty on the vertical section. Nowadays tv will automatically shuts off if you have a problem on the vertical output I.C. to protect your tube for burning the phuspor right on the middle of the screen which will affect on the picture later on.
I've adviced you to look for a qualified technician to isolate and replaced the faulty parts and do resoldering for some dry joints because sometimes dry joints damaged the parts.
Thanks for using fixya...
JVC AV-32S575... | Answered on Jan 06, 2011
its a ghot you can call ghost busters and they can get rid of it for ya. Just kidding it might be something on the inside touching eachother that shouldn't,Dust can also cause this.good luck
JVC AV-32S575... | Answered on Dec 24, 2010
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
JVC AV-32S575... | Answered on Nov 08, 2010
if its wired to cable/satelite test scart leads unplugg /plug back in and if you have xbox unplug that while watching tv then plug in when u want to use it hope this helps it worked on mine
JVC AV-32S575... | Answered on Jul 18, 2008
Prior to disassembly, unplug the power plug from the AC outlet without fail. (Turn the power "off".) Short the SB connector [1] pin and [2] pin of the DIGITAL INPUT MODULE PWB. (At the time of assembling) Before the rear cover is inserted into the cabinet,release the short-circuit between the SB connector [1]pin and [2]pin of the DIGITAL INPUT MODULE PWB. After releasing the short-circuit between the SB connectors, do not turn the power on until the rear cover is inserted into the cabinet. Negligence in carrying out the above steps may cause the inactivation of the TV.
JVC AV-32S575... | Answered on Oct 02, 2007
JVC AV-32S575 32" TV Logo
Popular Tags
24 questions posted
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
black rectangle
  • Televison & Video
