20 Most Recent Vtech V.Reader Interactive Reading System Questions & Answers
My grandaughter v-reader is stuck on calibration mode will not advance to activity screen. Has anyone come up with a sloution to this problem?
You have to go here, download, put the SD card into the computer, let it do it's thing - then, put the SD card into the VReader, let IT do IT'S thing, LOL, then take the SD card out of the VReader and it's done! Mine was stuck on the calibration screen as well, but this fixes it - you have to do this to set it all up correctly. It's part of the download process.http://www.vtechkids.com/download/
1/4/2020 12:19:26 AM • Vtech V.Reader... • Answered on Jan 04, 2020
Vtech v.reader reading SD card
The SD Card may be broken
1/10/2018 4:06:48 PM • Vtech V.Reader... • Answered on Jan 10, 2018
4answers
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
10/5/2014 6:44:58 PM • Vtech V.Reader... • Answered on Oct 05, 2014
It turns on, but nothing else
take out the batteries; remove cartridge. press hold power button for 30 seconds. place batts back in and try to turn toy on
5/14/2014 8:00:16 PM • Vtech V.Reader... • Answered on May 14, 2014
My storio wont load up, when its turned on it just goes to a blue screen
go to this link:http://www.vtechkids.com/download/ click V.Reader>>click recover program creator
5/14/2014 7:59:29 PM • Vtech V.Reader... • Answered on May 14, 2014
The touchscreen of my sons vtech storio wont work, even after calibration? he only got it yesterday for christmas!
connect your toy to the Learning Lodge. Go to Calibrate Touch Screen option....make sure that you are also using fresh batteries.
5/14/2014 5:36:14 PM • Vtech V.Reader... • Answered on May 14, 2014
Wont turn on after update
hhkhik ihhhi
11/17/2013 9:22:02 PM • Vtech V.Reader... • Answered on Nov 17, 2013
V.reader is stuck in engineering mode with ADC numbers moving raptt
mnvhvhvhhjh,hk
11/17/2013 9:21:37 PM • Vtech V.Reader... • Answered on Nov 17, 2013
Hello. My vtech storio the calibration blocks.
Dl the newest driver after cd install
8/4/2013 11:12:36 AM • Vtech V.Reader... • Answered on Aug 04, 2013
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
11/28/2012 8:39:33 PM • Vtech V.Reader... • Answered on Nov 28, 2012
V.Reader Screen is white!
this prob means that your screen has ether come disconnected from it input port or is broken and the input section, your best bet would be to take it to geek squad so as not to void the warranty but if that is not an option you, need to take it apart and look at where the screen connects to the motherboard and see what is wrong, if it is the screen that is broken you can get another one but it will prob cost more then a new V. reader
9/19/2012 6:37:17 PM • Vtech V.Reader... • Answered on Sep 19, 2012
Why won't my child's Vtech turn on?
take it some where it may be fix
7/25/2012 2:20:08 PM • Vtech V.Reader... • Answered on Jul 25, 2012
Says flip engineering mode
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution. Thank you for using FixYa.
2/9/2012 8:48:48 PM • Vtech V.Reader... • Answered on Feb 09, 2012
I have a V-Tech Touch and Learn Activity Desk Deluxe. How do I take it apart?
Hi there, there doesn't seem to be any specific information online for how to take it apart, but I've attached the user manual as a link to reverse the process. It seems you can easily remove the "shoulders" from the "base", all four legs can be detached easily, and the stool has removable legs as well. Hope this helped.
12/25/2021 4:31:13 PM • Vtech Toys • Answered on Dec 25, 2021
Vtech V.Reader Interactive Reading System Logo
Popular Tags
31 questions posted
Top Vtech Toys Experts
tina gallow
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Vtech Toy Expert? Answer questions, earn points and help others
View Most Popular
Vtech Toys
  • Vtech Toys
Most Popular Question
vtech storio in touchscreen calibration
  • Toys
