20 Most Recent Hasbro Nerf N-Strike Stampede ECS Blaster Questions & Answers
0answers
0answers
0answers
My stampede got wet and will not fire. how do i
Let it dry in a hot place for a couple of days and try it again. Hopefully at this point you have not fried any crucial components, otherwise you will just have to buy a new one.
10/15/2013 10:41:13 PM • Hasbro Nerf... • Answered on Oct 15, 2013
0answers
0answers
0answers
Our Nerf Stampede will not
Have you checked the jamming inspection panel is pushed forward and the green light is on?
1/17/2012 1:24:46 AM • Hasbro Nerf... • Answered on Jan 17, 2012
I just got my new
There are multiple factors in the inconsistency of your product's functioning.
1.) You have not successfully screwed in the battery cartridge tight enough so as the metal conductors are touching (with pressure).
2.) Your batteries are dead or almost dead.
3.) You put 4 bullets in your clip - kidding :)
4.) The circuitry may not be high quality, was your gun tampered with or from an unreliable source?
5.) Your jam door may not be high quality and could often slip from its locking point, I'd suggest taping it momentarily to keep pressure on it just to see if this is the case.
6.) The clip may be loosely in also, I'd also look into that.
If your gun stopped working permanently- I'd suggest looking inside at the white plunger, and the parts that release it from its pressurized position. There are many diagrams on the internet of the internals for it.
Email me a [email protected] for more info.
2/28/2011 10:29:42 PM • Hasbro Nerf... • Answered on Feb 28, 2011
I have the Nerf Stampede
1.) Check to see if the batteries are inserted right.
2.) If for some reason they aren't pressed up against the metal right, add metal between the batteries and the conductors to insure they are in full contact.
3.) Did you screw in the battery pack all the way? I'd check that.
4.) (The hard) look inside the gun (unscrew the plates) and find out if the circuit is 'complete'. One of the factors in the gun's circuit being complete (jam door, batteries, or clip) may not be working the proper way.
Good luck with your problem.
Also- are you sure they are brand new?
Try getting a full refund if you can, if all else fails.
Take a few pictures of the internals and email them to me at [email protected]. I'll try to see if I can come up with a probable answer.
2/27/2011 10:36:57 PM • Hasbro Nerf... • Answered on Feb 27, 2011
Stampede ECS won't fire the
I had this same problem. Well, actually after I modded it. I hope you are good with your hands, because this takes effort.
Unscrew the casing and open the gun (remember to take the battery pack out and have the two plates together so that the wire connecting them doesn't break).
When you see the plating covering the plunger (spring) system take it off, it has about 5 screws.
Since this is extrememly hard to explain in words, look at an internet picture of the internal plunger system. The way it works is that when the spring/tube goes forward (as the motor operates) the 'plunder' (the white thing) stays back. As the orange tube goes forward it triggers and release mechanism that fires the plunger forward due to spring pressure, compressing the air, therefore firing the bullet.
All you have to do (which is what I did) is insert a clip (with the plates open), make sure the jam door is closed, and put the battery pack in (to complete the circuit). Do a bunch of test runs to make sure the white plunger is shooting forward as the mechanism operates.
This will all make sense once you activate the gun without base plates.
Email me at [email protected] if you complete it, have questions and/or comments.
I hope it helped!
PS- while you're at it, you might as well look for online instructions on how to mod the air restrictor (as I am too lazy to write a few more paragraphs!).
2/27/2011 9:03:41 PM • Hasbro Nerf... • Answered on Feb 27, 2011
It wont shoot nothing that
Assuming NEW batteries were installed, the gun could be jammed from the start after loading. There is not much that can be repaired for this toy. You can click on the link for product details>
http://www.hasbro.com/common/documents/3f4e2ca7206011ddbd0b0800200c9a66/1F42A29A19B9F3691052D4826DE1FF72.pdf
You can aslo contact Hasbro 1-800-327-8264 for a replacement.
1/30/2011 1:02:53 PM • Hasbro Nerf... • Answered on Jan 30, 2011
Hasbro Nerf N-Strike Stampede ECS Blaster Logo
32 questions posted
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
View Most Popular
Hasbro Toys
  • Hasbro Toys
Most Popular Question
nerf stampede
  • Toys
