20 Most Recent
Schiller AT-2 EKG Questions & Answers
How do you change schiller ekg from 6 lead to 12 lead?
6 lead / 12 lead EKG. It is unlikely that you can do that with your machine. 6 leads are rarely used and would require a totally different internal format. 12 lead Ekg is the standard of care. Chose 12 lead and dont worry about finding a 6 lead. RJ
With manythanks,can someone mail the user manual or handbook for schiller ecg/ekg at 3 ?
Manual for AT-2 (I presume that it's similar to AT-3) says that language may only be changed with SWUP program (whatever that means). To change date: ALT - 9 - 2 - 2 - D - D - M - M - Y - Y
To change time: ALT - 9 - 1 - 1 - H - H - M - M - S - S
To reset clock to start counting: ALT - 9 - 9 - 9 - 2 - 1 - 0
NOTE: This is settings for SCHILLER AT-2, I'm not sure that'll work with AT-3.
I hope this was helpful.
What type of paper does the AT2 plus use? Can you tell me where to get it?
Greetings. The schiller AT2/2+/2+light uses a Zfold paper with a black queing mark. You can order the paper from Precision charts inc. You can find the contact info for PCI on the internet. Also you can order from whoever you get your normal nedical supplies from such as Mckessen, Cardinal, etc.The correct number is 2157-017A, and it is usually sold in cases of 8 packs.
Schiller AT 2 plus does not recognize the leads.
internal circuit of the unit needs to be checked if there is a short inside the machine will not detect the leads.also check out the leads in another machine to confirm the faulty part.
thanks.please keep
updated.please do rate the solution if helped.thank you for using fixya.
