20 Most Recent JVC TH-A75R System Questions & Answers
The port on the jvc is probably an input, which does not produce light. Only optical outputs will have the red light in them.
JVC TH-A75R... | Answered on Jan 04, 2013
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
JVC TH-A75R... | Answered on Sep 14, 2011
claire_unbre:
When you say laser eye, are you referring to the laser used to read your cd's & dvd's? if so, you can find dvd cleaners at most retail stores. the kit will contain a disc that looks like a dvd with built-in brush & cleaning solution. follow the instructions on the cleaning kit & you should be OK. reply if you need additional assistance.
peace-out
JVC TH-A75R... | Answered on Feb 06, 2009
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
JVC TH-A75R... | Answered on Feb 05, 2009
Hi hope this helps. ....cheers
JVC Audio... | Answered on Nov 26, 2019
JVC TH-A75R System Logo
Popular Tags
8 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
jvc tha75 r laser eye bit clean
  • Audio Players & Recorders
