20 Most Recent JVC TH-C3 System Questions & Answers
No power in surround sound system(DVD/subwoofer)
The key could be the word "move". Electrical items can get knocked moving and something might have become loose or damaged inside the sub. So check it out. Inside too!
3/2/2018 12:44:10 AM • JVC TH-C3 System • Answered on Mar 02, 2018
manual
0answers
8-pin din to rca adapter
Hi, check the link bellow. You will some of them. Choose wich suits your purpose. 8 Pin din to rcaAjin
7/25/2012 5:53:50 PM • JVC TH-C3 System • Answered on Jul 25, 2012
DVD Player wont eject, Locked
disassemble the unit and eject manually
1/25/2012 6:50:03 PM • JVC TH-C3 System • Answered on Jan 25, 2012
Where can I buy the 8 pin cord ?
try jvc web site www.jvc.com the last time i was on their site i saw 8 pin din for sale.Try it good luck.
1/7/2012 11:54:32 PM • JVC TH-C3 System • Answered on Jan 07, 2012
No sound from speaker system,
How about the basic speaker test or onboard FM?
8/27/2011 9:17:40 PM • JVC TH-C3 System • Answered on Aug 27, 2011
How can i make the
Source the TV-related sound (probably from the cable box, huh?) as if it is an external audio device, which it IS. The TV need not be a part of the audio path. Some of us have monitors without speakers. It doesn't seem to be a show-stopper.
4/17/2011 10:11:47 PM • JVC TH-C3 System • Answered on Apr 17, 2011
My disks won't play in color just black and white
If you're using component video cables check them all for good connection.
1/20/2010 3:46:40 AM • JVC TH-C3 System • Answered on Jan 20, 2010
2answers
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
1/8/2010 3:28:29 AM • JVC TH-C3 System • Answered on Jan 08, 2010
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
12/9/2009 12:42:04 PM • JVC TH-C3 System • Answered on Dec 09, 2009
When I turn the device on, it turns off almost immediately
Have you checked your speaker wire some times when you turn on something it will shut off if there is a wire touching each other. also if you have a fan that cools your system if it doesnt work nothing with high power will the am fm radio will run but your system is getting hot by what it touchs
12/9/2009 3:48:19 AM • JVC TH-C3 System • Answered on Dec 09, 2009
Speaker is not working, although
remove the speaker that is inop and hook that channel up to a good speaker, this will test the speaker, if the substituted speaker works then u need to replace the speaker that is inoperable, if the known good speaker doesn't work then the amplifier is defective or the speaker wiring is defective, check the connection for that inop speaker at the amplifier, insert and remove the wires several times to make sure you have a good clean connection, if this still doesn't get the speaker to work on that channel you have a defective amplifier.
10/17/2009 7:15:08 PM • JVC TH-C3 System • Answered on Oct 17, 2009
Our power went out briefly and now the DVD player won't turn on
Hello sir/ma'am, my guess is that the dvd player's power supply fuse gave in. Im not familiar with your dvd player, if you can open the dvd player and locate the check the fuse. replace it if its blown up. hope this helps. if you may have any more inquiry feel free to ask me again. best regards, thanks.
7/15/2009 3:54:38 AM • JVC TH-C3 System • Answered on Jul 15, 2009
0answers
No power to subwoofer
The subwoofer is designed to be "on" at all times. It will detect signal from the cable and should start by itself. So yes, the pin cable must be connected.
Dan
8/26/2008 1:30:29 PM • JVC TH-C3 System • Answered on Aug 26, 2008
No Power
I just recently moved back home to NY and hen I plugged in my subwoofer I have no power
8/8/2008 3:57:24 PM • JVC TH-C3 System • Answered on Aug 08, 2008
DVD plays in black and white
Go into dvd player settings and into video settings as i think you have set this to s-video if this hase happened change it to video or RGB if you can.
HOPE THIS HELPS.
CABLE GUY.
7/20/2008 3:42:21 PM • JVC TH-C3 System • Answered on Jul 20, 2008
JVC TH-C3 System Logo
Popular Tags
31 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
listen dtv dvr output th c3
  • Audio Players & Recorders
