20 Most Recent
JVC HXD7 5-disc Home Stereo Theater System DVD changer Shelf System Questions & Answers
Two issues with this system
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
regards
Graeme
INNOVAGE JUMBO REMOTE CONTROL
Try pressing the channel up button multiple times to see if you can help the remote find the code. If you push the channel up button enough times and "something happens" then immediately press the mute button to save the code. It worked for my Sylvania tele.
Need help
I have this stereo and so do 2 friends. We've all had the same problem but I turned my stereo into a certified repair shop and they fixed the problem. I think something on one of the PCB's inside the unit misaligned. I didn't pay more than $50 for the repair. There was no major repair they told me.
Please help
Press and hold the RHYTHM button until the display flashes. The factory default settings are restored and all the settings you have made are erased.
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
