20 Most Recent JVC MX-J30 CD Shelf System Questions & Answers
Just about any electronics or big box store (Walmart, Target, etc.) will have an FM antenna. They will be in the electronics section.
JVC MX-J30 CD... | Answered on Mar 18, 2015
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
JVC MX-J30 CD... | Answered on Dec 12, 2014
There are a couple of things going on here.
The CD issue is, uh, common. They die. CD-cleaners are dubious at best.
http://www.repairfaq.org/sam/cdfaq.htm
For the remote, try this advice:
http://remotes.com/remotes/servlet/rs?=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the
unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
eBay has some RM SMXJ30J remotes cheap. This one will set you back $11.50 delivered.
http://cgi.ebay.com/JVC-RM-SMXJ30J-REMOTE-CONTROL-/120717037068?pt=LH_DefaultDomain_0&hash=item1c1b4bce0c
JVC MX-J30 CD... | Answered on May 07, 2011
please check the input voltage and adjust it
JVC MX-J30 CD... | Answered on Aug 21, 2010
hello you may have ac power but no dc power take the cover off and have a look for any swollen capacitors or components that might be burn't
regards
shaun
JVC MX-J30 CD... | Answered on Feb 14, 2010
Spares from JVC? Where's the cheapest remote? Where's the cheapest Service manual?
JVC MX-J30 CD... | Answered on Feb 08, 2010
If it has a aux input at the back you can get a dock and that will let you plug it into your system.
JVC MX-J30 CD... | Answered on Feb 04, 2010
Probably a poor suggestion, but you may want to look for a reset button on the back or the front. It is usually recessed and about the diameter of a paperclip. The electronics may be "confused".
JVC MX-J30 CD... | Answered on Jan 16, 2010
Hi sorry cant be modified to do but what you could do is use an external player and plug it into the AUX input on the back
Hope that helps
JVC MX-J30 CD... | Answered on Jul 22, 2009
Failure of this laser is quite common giving a no disc message in the HiFi's display. A defective laser can also be responsible for an intermittent no disc message and general playability problems with CD discs. Part number Optima 7 / 7B Laser Assembly
JVC MX-J30 CD... | Answered on Feb 15, 2009
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
JVC MX-J30 CD... | Answered on Dec 31, 2008
First, contact Bell and inquire whether their remote control contains the appropriate code.
JVC Audio... | Answered on Jan 10, 2021
Contact JVC to request.
JVC Audio... | Answered on Jan 03, 2021
Request the manual directly from JVC.
JVC MX-J30 CD Shelf System Logo
23 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
jvc mxj30 compact fi
  • Audio Players & Recorders
