20 Most Recent JVC FS-SD9 Shelf System Questions & Answers
0answers
Why do i lose station memory
You may have an alkaline battery in the back of it that needs replacing.
7/31/2014 8:09:25 PM • JVC FS-SD9 Shelf... • Answered on Jul 31, 2014
0answers
Keeps skipping songs on
This is a laser pickup problem, overtime the laser becomes weaker until it reaches point it can not track properly and starts skipping until it fails. One possible solution is clean the laser lens with a Q-Tip and rubbing alcohol that might solve the problem. To replace the assembly would not be cost effective to repair, cheaper to replace.
2/2/2011 7:26:23 PM • JVC FS-SD9 Shelf... • Answered on Feb 02, 2011
/what shoul I do when the CD spins but does not
throw it out
5/1/2010 9:30:17 PM • JVC FS-SD9 Shelf... • Answered on May 01, 2010
Does the JVC UX-A4 have aux inputs for a separate turntable to play through amp?
It does have an aux input with two levels but this isn't suitable for a turntable. A suitable input should have RIAA correction with a sensitivity of just a few millivolts for a magnetic cartridge. Instruction manual can be found on the link below... http://resources.jvc.com/Resources/00/00/90/LVT1519-001C.pdf
3/7/2024 10:42:20 AM • JVC Audio... • Answered on Mar 07, 2024
I have jvc th a75r hardret plz help
Here is the user manual; https://www.manualslib.com/products/Jvc-Th-A75r-252593.html
3/4/2024 7:47:22 AM • JVC Audio... • Answered on Mar 04, 2024
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue: Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection. Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue. Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues. Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on. If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM • JVC Audio... • Answered on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first; Insert CD, the first thing the processor expects is to scheive Focus. When Focus is acheived, the Spindle Motor will turn. Either the Laser cannot Focus or there is an issues with the Spindle Motor. Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM • JVC Audio... • Answered on Jan 29, 2024
JVC MX-GC5 3-CD/AM/FM shelf system with USB. What makes my CD motor not working it's not playing any CD's?
Question edited for a lot more clarity and toss in a load of CAPS. Can you hear the CD Motor spinning? If so, probably this https://www.fixya.com/support/r29927004-dvd_player_or_cd_player_not_reading If not, the CD Unit has failed, or the power supply to it. A JVC Service Centre should be able to fix it. ..
1/16/2024 11:43:06 PM • JVC Audio... • Answered on Jan 16, 2024
JVC FS-2000 radio. How do I turn off the alarm on it please?
Question edited for clarity, toss in some CAPS, add the Magic word. Strangely there is no owners manual but there is a Service Manual for it. It appears that it is actually a 'JVC FS-2000GD'? Normally turning off the alarm just requires pressing the Alarm Set button one more time to toggle it off. Or you can disconnect it from the mains, remove any back up batteries if it has them and it will reset everything. Then set the time.
JVC FS-2000GD Service Manual download, schematics ...
Elektrotanya https://elektrotanya.com > download ยทTranslate this page Download JVC FS-2000GD service manual & repair info for electronics experts.
12/31/2023 6:12:21 AM • JVC Audio... • Answered on Dec 31, 2023
User manual for JVC CA-D8T in english
Download service manual. Operating instructions are also given in english. JVC CA-D8T SM Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
12/28/2023 12:02:50 PM • JVC Audio... • Answered on Dec 28, 2023
JVC UX-P550 Music Unit. Do I need a remote for full user ability?
Question edited for clarity and toss in some CAPS.. Yes, it looks like you do. Replacement Remotes https://www.google.com/search?q=jvc+ux-p550+replacement+remote
JVC UX-P550 Instructions Manual
ManualsLib https://www.manualslib.com > ... > UX-P550 View and Download JVC UX-P550 instructions manual online. JVC Micro Component System Instructions. UX-P550 stereo system pdf manual download. ..
11/3/2023 5:18:04 PM • JVC Audio... • Answered on Nov 03, 2023
JVC THG30 1000-Watt Home Theater System. There is no music coming out. Any suggestions? Please help.
Question edited for a lot more clarity. All questions need 'make model (what it is)' please. Question moved from Computers. Troubleshooting. Check all the wires at the back. https://www.google.com/search?q=JVC++th-G30+no+sound ..
8/20/2023 2:19:02 AM • JVC Audio... • Answered on Aug 20, 2023
Where can I find a replacement remote control for my JVC RX-664V AUDIO/VIDEO reciever?
https://www.replacementremotes.com/jvc/rx664v-audio-system
8/8/2023 8:49:34 PM • JVC Audio... • Answered on Aug 08, 2023
How can I fix the auto mute on my jvc E100SL?
If your JVC E100SL receiver is showing an "Auto Mute" message and you are unable to perform a factory reset successfully, there are a few troubleshooting steps you can try to resolve the issue:
  1. Check speaker connections: Ensure that all speaker wires are securely connected to the receiver and the speakers. Loose or disconnected speaker wires can trigger the auto mute feature as a safety measure.
  2. Check the speaker impedance: Verify that the speakers you are using with the receiver have the correct impedance (measured in ohms) that matches the receiver's specifications. Using speakers with incompatible impedance can trigger auto mute.
  3. Inspect the wiring: Check all audio input and output connections to make sure they are properly connected and not damaged. A faulty or damaged cable can cause the auto mute feature to activate.
  4. Unplug and reset: Turn off the receiver and unplug it from the power source for about 10-15 minutes. This will allow the receiver to reset, which might resolve any temporary glitches or errors causing the auto mute.
  5. Check for overheating: Overheating can trigger safety features like auto mute. Ensure that the receiver has adequate ventilation and is not placed in a confined space. Clean any dust or debris from the vents to improve airflow.
  6. Perform a hard reset: If the factory reset procedure is not working, you can try performing a hard reset. To do this, locate the reset button on the receiver (usually a small pinhole) and use a paperclip or a similar tool to press and hold the button for about 10-15 seconds. This should reset the receiver to its default settings.
  7. Update firmware (if applicable): Check the JVC website or contact their support to see if there are any firmware updates available for your receiver. Updating the firmware can sometimes resolve software-related issues.
  8. Seek professional assistance: If none of the above steps resolve the auto mute issue, it's best to contact JVC customer support or take the receiver to a qualified audio equipment repair technician. They will have the expertise and diagnostic tools to diagnose and fix the problem accurately.
Always be cautious when attempting to troubleshoot or repair electronic equipment. If you are not confident with electronic repairs, it's best to seek help from a professional to avoid causing further damage to the receiver or risk of injury.
7/25/2023 4:54:21 PM • JVC Audio... • Answered on Jul 25, 2023
JVC FS-SD9 Shelf System Logo
8 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
keeps skipping songs
  • Audio Players & Recorders
