20 Most Recent Midwest Mwcbk Sock Monkey Clips Primary Set of 4 Questions & Answers
Disconnect the electrical connector that joins the arches. Unscrew the half of the arch that holds the batteries. Check the red lead from the battery compartment. Mine had two problems - it was almost disconnected from the battery, and had another disconnect in the middle. Twist the wires together at both fault points and tape (electrical tape) or solder. I soldered and my Learning Home is now working perfectly.
--gdipersio
Toys | Answered on Nov 16, 2020
There are tutorials and video's on YouTube and on Goggle then on how to make your own decorations for birthdays and for Christmas and Easter and Halloween and for Valentines day too.
Toys | Answered on Nov 11, 2020
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
I found this on a review of the dog:
Playing with Lucky is pretty simple but does require some learning. Lucky is programmed to respond to 15 different commands but the commands must be issued the same way each time. First, you say Lucky's name to engage him. Once you say "Lucky" (or whatever name you give him) he will then respond to you with 2 barks. After he goes ruff-ruff, then you can tell him what to do. The commands are as follows:
Speak to Me - he will sit or stand & bark
Come Here - he will run forward and back
Pounce - he will crouch and pounce excitedly
Lay down - he will lay down on his tummy
Sit - he sits
Want a Treat? - he stands and barks (begs)
On your head - He does a headstand
Go to sleep - lays down, snores and enters sleep mode
Sing a song - he'll bark one of 2 songs
Good Dog - acts excited by shuffling his feet
Bad Dog - he crouches down
Put 'em up - he'll stand up on his hind legs. Then when you say "bang bang" he plays falls down and plays dead.
Tug of War - he opens his mouth for you to put in his leash, he closes his mouth and tugs a little
Lucky also comes with a "sleep" mode and automatically shuts off after not being played with for 3 minutes.
Playing with Lucky is pretty simple, you command and Lucky performs. Well, Lucky performs most of the time. You need to be sure that he has your attention (barking twice) first before issuing the command. A few of the tricks are a bit more complicated - Put 'em up & Tug of War but the rest are very straight forward. I do notice that both my husband and I had the tendency to want to 'yell' or raise our voices when commanding Lucky - but that isn't necessary.
Toys | Answered on Aug 15, 2020
Helps to get back each and every inaccessible Outlook items such as emails, calendars, notes, tasks, journals, contacts, etc from Outlook personal folders and make them workable without loss any data. See at:- Outlook Emails Recovery
Toys | Answered on Jul 27, 2020
If the santa has no built in bluetooth or memory slot then the nest best thing is to place a bluetooth speaker inside the santa and then play songs.
Toys | Answered on Jul 15, 2020
I just bought these at a yard sale today. Did anyone find an answer to this or know what the name of the toy is? Manufacturer?
Toys | Answered on Jun 27, 2020
No, it is not possible. Since the records is with your bank - the other bank ATM will not accept this option. Therefore, you cannot use other bank ATM to change the pin. Even when you receive the debit card first time, you have to activate your card in the ATM of your bank only initially and not with another bank ATM
Contact the manufacturer on facebook. Message them that you need a copy. I got mine the next day.
https://www.facebook.com/rowlinsongp/
Toys | Answered on Jun 17, 2020
Instructions for Imaginarium Pirate Island
http://www.docstoc.com/docs/document-preview.aspx?doc_id=135875316
Toys | Answered on Jun 06, 2020
Hello Card Dia, The educational learning toys are designed to inspire the interest of infants and babies. All products are correctly designed for children that are 1 month to 7 year old. Before a few months ago I bought some Montessori materials from Kidadvance.com online shop for my 6 years old son. Now his brain is improving quickly.
Toys | Answered on May 21, 2020
Sounds like the control switch has an open in it. Move it back and forth several times to see if it gets a connection back.
Toys | Answered on May 20, 2020
Midwest Mwcbk Sock Monkey Clips Primary Set of 4 Logo
1 questions posted
Top Midwest Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Midwest Toy Expert? Answer questions, earn points and help others
View Most Popular
Midwest Toys
  • Midwest Toys
Most Popular Question
black spider xt indoor helicopter front
  • Toys
