20 Most Recent Mintek MDP-1810 Portable DVD Player Questions & Answers
2answers
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
5/7/2020 1:45:13 PM • Mintek MDP-1810... • Answered on May 07, 2020
2answers
No disc error
1/10/2020 6:06:13 AM • Mintek MDP-1810... • Answered on Jan 10, 2020
Computer burned DVD will not play on Mintek model MDP-1810 portable DVD player
Do you use a DVD burning program or DVD copy program to convert ISO file to DVD? Normally, if you not, it is just data DVD and not a playable DVD disc for DVD player machine. You can try to use some programs to copy ISO to DVD such as Leawo Blu-ray Copy or Windows Disc Image Burner. Microsoft has included a default feature of burning ISO files to DVD disc.
1/10/2020 6:03:20 AM • Mintek MDP-1810... • Answered on Jan 10, 2020
2answers
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
11/14/2019 3:23:22 AM • Mintek MDP-1810... • Answered on Nov 14, 2019
0answers
Battery
Be the first to answer 8/25/2012 3:26:07 AM • Mintek MDP-1810... • Posted on Aug 25, 2012Be the first to answer
0answers
My screen is cracked where can i get it fixed
see the cause and fix it:1er alternative:
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
  4. 2nd alternative:
  5. Enter Setup and then Player menu to select the correct screen format.
  6. Select the screen format from the DVD disc menu or press zoom key.
7/22/2012 8:17:53 AM • Mintek MDP-1810... • Answered on Jul 22, 2012
How long does it take to charge the battery on a mintek MDP-1810 portable dvd player?
In most cases 8 to 12 hours to fully charge.
7/19/2012 6:57:31 PM • Mintek MDP-1810... • Answered on Jul 19, 2012
Need cords
i would advise a universal ac adapter one of the adapters with the adjustable voltage and the changeable heads
3/8/2011 6:51:24 PM • Mintek MDP-1810... • Answered on Mar 08, 2011
Will the player work with the battery off and
I believe it can play ought right from AC without battery attached. In fact always playing it with battery AND AC could overcharge and kill the battery before its time.
Enjoy your player
3/1/2011 7:12:59 PM • Mintek MDP-1810... • Answered on Mar 01, 2011
What video cable is used with this player? I lost
This player has two video output types, composite (yelllow RCA jack) and S-Video (mini DIN jack) , for better video use the second one and look for a S-Video cable, in example, at an Electronis parts store.
2/22/2011 3:44:10 AM • Mintek MDP-1810... • Answered on Feb 22, 2011
2answers
The optical reader assembly moves freely and the
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens).
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this is done, your player will play all DVD discs again.
Good luck.
1/9/2011 12:52:14 AM • Mintek MDP-1810... • Answered on Jan 09, 2011
Remote Control not working
take a digital camrea or a camrea phone point the remote sensor (the bit you would aim at your player) towards the lens of the camrea and look on the camrea/phone display press buttons on the remote can you see a flashing light coming from the sensor ?? if not its due too a flat battery or faulty remote if you do then its likely too be a fault with the player
12/9/2010 8:12:36 PM • Mintek MDP-1810... • Answered on Dec 09, 2010
Mintek MDP-1810 Portable DVD Player Logo
41 questions posted
Top Mintek Televison & Video Experts
Steven Wander
Steven Wander
Alexander
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mintek Televison & Video
Most Popular Question
problem reading disk
  • Televison & Video
