20 Most Recent JVC RX-884V Receiver Questions & Answers
Decoding Blu Ray
Did you try changing the audio to 5.1 instead of 7.1 in the audio tracks of the blu Ray?
1/17/2018 12:31:52 AM • JVC RX-884V... • Answered on Jan 17, 2018
8answers
JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
11/7/2015 2:44:02 AM • JVC RX-884V... • Answered on Nov 07, 2015
manual
0answers
No display
Be the first to answer 4/11/2014 3:25:40 AM • JVC RX-884V... • Posted on Apr 11, 2014Be the first to answer
0answers
0answers
When I hook up the rear speakers to my in-wall
Hi:
you need to clear that you connect wall speakers for font,center or rear (surround) speakers?
Seem you connect for Front speaker.
Rear (surround) speaker will have "rear" mark on the back of your reveiver.
In general you need to select both buttons 1 & 2 then check your speaker wires connect into "output1" or "output 2" hint: each output will have 1 for left and 1 for right speaker. Each Left or right speaker will have 2 connection 1 red color (+) and 1 white color (-). Try to match these colors code for your speakers connection.
2/25/2011 8:09:30 PM • JVC RX-884V... • Answered on Feb 25, 2011
How connect to tv
http://resources.jvc.com/Resources/00/00/96/LVT0380-001A.pdf this is a manual for the rx 6000 it's the same connections as my reciever pioneer hope works...............video out to TV, all components video in to receiver
2/20/2011 7:26:06 AM • JVC RX-884V... • Answered on Feb 20, 2011
I turn up the volume and sound shuts down, and
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
2/5/2011 12:39:49 AM • JVC RX-884V... • Answered on Feb 05, 2011
JVC RX-884V 5.1 Channels Receiver Problems &
4171, 4176, 4149,4141
9/26/2010 6:11:00 AM • JVC RX-884V... • Answered on Sep 26, 2010
I want surround sound. How do I hook up my audio
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
6/26/2010 3:57:16 PM • JVC RX-884V... • Answered on Jun 26, 2010
JVC RX-884V Receiver Logo
28 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
Marvin
Marvin
Gary
Gary
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
decoding blu ray
  • Audio Players & Recorders
