20 Most Recent GE 21 cu ft Top-Freezer Refrigerator White ENERSTAR GTH21GCEWW Questions & Answers
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
GE 21 cu ft... • Answered on Aug 27, 2014
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gsl25jftabs-repair/gsl25jftabs-frost-buildup.html I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
GE Freezers • Answered on Jan 02, 2018
The 6 or7 may be a setting number or a degree readout, which is a little on the warm side, should be around a -10 to-15. Consult your users manual for details ,.Does not sound like an emergency, but keep monitoring it' https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help This site may be of help. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
GE Freezers • Answered on Dec 15, 2017
It sounds like this is a a non DIY issue. there is really not much you personally can do. Contact an authorized servicer fir best results Good luck! I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Gaskets can cause this, along with internal fans getting bad or iced over. Other answers might indicate a leak of freon.
GE Freezers • Answered on Sep 29, 2017
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
GE Freezers • Answered on Aug 11, 2017
Make sure the electricity is connected. Check the start capacitor - check for the compressor running.
GE Freezers • Answered on Dec 15, 2016
Have you tested the wall socket for power, do that first.
GE Freezers • Answered on Nov 23, 2016
They are usually for extra ddehumidification based on the area you live in. If your freezer is working correctly, I would just leave them where they are at
GE Freezers • Answered on Aug 17, 2016
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
GE Freezers • Answered on Jun 27, 2015
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Look on the sides or back for a louver. It's behind the louver.
GE Freezers • Answered on Jun 09, 2015
Does the noise start when you push fast freeze? It bypasses the thermostat. If the green light is out it may just be the light itself and nothing to worry about. Check power to the freezer!
GE Freezers • Answered on May 15, 2015
GE 21 cu ft Top-Freezer Refrigerator White ENERSTAR GTH21GCEWW Logo
1 questions posted
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Dan Webster
Dan Webster
Are you a GE Freezer Expert? Answer questions, earn points and help others
View Most Popular
GE Freezers
  • GE Freezers
Most Popular Question
plastic door shelves fall out
  • Freezers
