20 Most Recent Rheem Ruud Weather King Corsaire Rheem RUUD Weather King Honeywell Furnace Gas Valve 60-100394-02 VR8205S2395 Questions & Answers
I would try the mfg. and see if they have a trouble shooting page and a teck guy
Rheem Ruud... | Answered on Oct 20, 2013
Usually on the inside cover of the door.
gethuman.com
Rheem Ruud... | Answered on Aug 03, 2014
Zamil a.c. EC error code show what is problem
Heating &... | Answered 15 hours ago
We bought a goldair air cooler ghc-803h yesterday and since last night it switches on and off the whole time, no timer is set on it?
Heating &... | Answered 16 hours ago
hi Jennifer.
this is all i could find.go to this link and see if it helps you to find out why.
Why is my PTAC unit so noisy in the winter months Google Search
Heating &... | Answered Yesterday
Check the wall outlet with something known to work. Check the plug on the end of the air conditioner as many have a press-button reset.
If it has a dehumidifier built in, check the water doesn't need to be emptied.
Anything more than that, you need a refrigeration engineer to look at it.
I moved your question to the correct category.
https://www.guzzle.co.za/specials/view/1196978/
Heating &... | Answered 2 days ago
you probably have air in the lines. keep trying to relight or maybe open a burner up and let it flow for a minute or two before relighting it
That information is stamped on the serial number plate.
It has a tip-over safety switch that needs resetting according to this
https://www.fixya.com/support/t1749282-honeywell_oil_heater_fell_over_its_side
The manual just says, place it upright and press the power button. Contact details are on Page 6.
https://www.manualslib.com/manual/388934/Honeywell-Hz-2030-Safety-Sensor-Heater.html?page=5
Heating &... | Answered 3 days ago
After two years of not being used, it needs servicing. You can't work on it yourself, because you need to be a qualified technician to work on gas appliances.
Heating &... | Answered on Jan 13, 2021
If the internal magic eye doesn't see a flame it will shut down for safety reasons.
As it isn't starting it could be fuel isn't being sprayed from the spray head or the spark is absent or perhaps the fuel is being sprayed but isn't in the finely atomised spray that burns easily.
Hearing and feeling the blower only proves the motor is running producing a combustion airflow; important but only when there is combustion. I am unfamiliar with the model but usually there is an air pump behind the motor that produces low pressure air to supply the spray head which works like a paint spray gun or carburettor - air is pushed through a venturi and creates a vacuum that sucks fuel from the tank.
It is possible the solid carbon vanes in the pump are stuck or damaged or there is a fuel blockage.
The spark transformer is highly stressed and they sometimes fail.
You will need to remove the cover and check a few things inside...
Rheem Ruud Weather King Corsaire Rheem RUUD Weather King Honeywell Furnace Gas Valve 60-100394-02 VR8205S2395 Logo
2 questions posted
Top Rheem Ruud Weather King Corsaire Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Rheem Ruud Weather King Corsaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
Rheem Ruud Weather King... Heating & Cooling
  • Rheem Ruud Weather King... Heating & Cooling
Most Popular Question
weather king furnace model number
  • Heating & Cooling
