20 Most Recent Hiace 200 series / wide after ending Genuine grille Questions & Answers
I have a 2006 Toyota(hiace) 2.4 diesel 2KDFTV MOTER PLZ FUEL filter light comes when engine start
Replace the fuel filter. Light indicated pressure drop in fuel line.
1/14/2015 7:05:52 PM • Hiace 200 series... • Answered on Jan 14, 2015
When i swith the car then the hiace fans were start but not shoew the check light and can never start
Sounds like a exhaust fan either not working or a bad sensor itself not showing the fumes have cleared so the unit will fire up properly
1/13/2015 6:17:47 AM • Hiace 200 series... • Answered on Jan 13, 2015
I have changed clutch brakes and cylinders, how to bleed clutch
Does the pedal feel normal? If it goes to the floor with no resistance you still have air in the hydraulic system. A fool proof, one person method is to attach a piece of rubber tubing (like a foot or so of vacuum hose) over the bleeder screw, open it about one full turn, put the other end of the hose in a container of brake fluid making sure the end is submerged, fill the master cylinder and pump the pedal slowly until the m/c is 3/4's empty. Refill it and do this 2 more times. This works on any system every time. If you slave cylinder still doesn't work you may have defective parts.
3/11/2014 1:28:41 AM • Hiace 200 series... • Answered on Mar 11, 2014
Air filter dash light came on after repalcing air filter what could be wrong?
Hi there Rohit check the switch in the air filter housing for damage when the filter was being changed also look for dust in it.
2/19/2014 4:12:10 PM • Hiace 200 series... • Answered on Feb 19, 2014
Car no drive
Check your Transmission fluid level to start.
12/10/2013 6:24:32 PM • Hiace 200 series... • Answered on Dec 10, 2013
Fuel light wont go off
CHECK SENDER UNIT IN FUEL TANK
11/19/2013 4:44:17 PM • Hiace 200 series... • Answered on Nov 19, 2013
Avensis t27
6/5/2022 4:03:32 PM • Toyota Vehicle... • Answered on Jun 05, 2022
Why remote start Avital 7111L cracks many times before to start a Toyota corolla 2017? Do I need open the car first to start it?
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
1/23/2019 9:09:38 AM • Toyota Vehicle... • Answered on Jan 23, 2019
Cannot turn my car alarm off. Viper 2001 Toyota Tacoma. Tried turning ignition on position valet button 5 sec turn off ignition doesn't work
could be the backup battery in the alarm that is at fault, this would keep the alarm activated due to its low voltage, the battery inside the unit has to be at a certain voltage, if it does not reach this voltage the alarm with activate.
4/2/2018 5:19:51 AM • Toyota Vehicle... • Answered on Apr 02, 2018
Srs warning light is flashing on Toyota Avensis 1998 gls saloon
Check wires under both seats are properly clipped together
2/22/2018 2:18:58 PM • Toyota Vehicle... • Answered on Feb 22, 2018
Como se activa la alarma de una toyota tundra
tengo una 2007 toyota tundra lumited 5.7,pero no me dieron el cotrol ,solo la llave y quisiera saber si con solo ka llave podria programar un nuevo control con el mismo sisteme de seguridad que tiene
2/20/2017 3:28:36 PM • Toyota Vehicle... • Answered on Feb 20, 2017
What might be the problem with my toyota axio,the engine starts when there is no MAF,BUT WHEN yuo plug it in the engine stalls
You need something like this obviously I am not involved in selling these but I needed a similar thing for my Vauxhall and it has saved me loads of money http://www.ebay.co.uk/itm/Toyota-Auris-Avensis-Aygo-Fault-Code-Reader-Scanner-diagnostic-scan-tool-UK-/320967310220?hash=item4abb247b8c
8/16/2015 3:34:56 PM • Toyota Vehicle... • Answered on Aug 16, 2015
2006 toyota tundra p/u truck alarm has shut down my truck want start, horn keep blowing
contact your toyota dealer to see whether they can offer any assistance
7/22/2015 2:58:34 AM • Toyota Vehicle... • Answered on Jul 22, 2015
Car security light won't stop flashing while driving?
Are you disarming the system with a remote or disabling by inserting the key. On some vehicles you may have a remote control key fob and a master key that works with no buttons, it is a straightforward key with no buttons that temporarily disarms the vehicles alarm for use, it does not fully disarm. When the alarm system is armed through the remote it can only be disarmed through the remote via the transmisson of a coded signal. Have you got these 2 different kinds of keys? Please add detail and resubmit the query
6/8/2015 10:31:44 AM • Toyota Vehicle... • Answered on Jun 08, 2015
Air not blowing out dash vents
vent control cable broke or switch no year given?
3/2/2015 11:44:15 PM • Toyota Vehicle... • Answered on Mar 02, 2015
Causes radiator hose collapse
hose needs replaced
3/2/2015 11:41:40 PM • Toyota Vehicle... • Answered on Mar 02, 2015
How does the main ignition fuse looks
usually likea 50 amp square one in fuse box next to battery
3/2/2015 11:36:10 PM • Toyota Vehicle... • Answered on Mar 02, 2015
Hiace 200 series / wide after ending Genuine grille Logo
7 questions posted
Top Toyota Vehicle Parts & Accessories Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Toyota Vehicle Parts & Accessories
Most Popular Question
2006 toyota hiace 2 4 diesel 2kdftv
  • Vehicle Parts & Accessories
