20 Most Recent Itronix GoBook III IX260 Notebook Questions & Answers
What is my ufone puk code
Itronix GoBook... | Answered on Nov 02, 2015
You can, but you need to make the USB stick bootable, which will delete everything on the drive and replace it with the Windows 7 install. You need what's called an ISO of Windows 7, which is basically a fancy word for an image of the install CD.
http://www.techverse.net/how-to-create-a-bootable-usb-pen-drive-for-windows-7/
Itronix GoBook... | Answered on Jan 20, 2015
Hi, Most likely you can not put 2 physical Hard drives. you can partition 1 drive into 2 partitions try partition Magic.
you can also try
http://download.cnet.com/EaseUS-Partition-Master-Free-Edition/3001-2248_4-10863346.html?hlndr=1&dlm=0
Good Luck...
Itronix GoBook... | Answered on Jun 28, 2014
Usually when these things stop working it has to do with the voltage getting to the receiver or the receiver itself. I suggest you have it replaced since it has probably just quit functioning. I mean the wireless card, not the gobook.
Itronix GoBook... | Answered on May 29, 2014
puk codes are provided by the network operators so better contact your service provider for the puk
Itronix GoBook... | Answered on Apr 03, 2012
what i would do is call your company from a different phone and they will unblock it thats what i did when mine did that it took about a minute that was all
Itronix GoBook... | Answered on Dec 31, 2010
may be old batteries,
try this
get some alcohol or colougne to cotton or piece of cloth.
clean battery's connectors by it and let it dry,
connect and try again
is this helpful?vote me..
Itronix GoBook... | Answered on Dec 03, 2010
Take out the memory boards. See if it boots to bios. If it does turn it off and put the memory boards back in. Should be fine after that.
Itronix GoBook... | Answered on Nov 21, 2010
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
Itronix GoBook... | Answered on Nov 06, 2010
Firstly, turn off the itronix IX260 and remove the battery. Turn the system upside down while its closed and unscrew all the screws the is holding the case together.
Force in a flat screw driver into the sides of the itronix IX260, in other to get it opened. The case is clipped together. The flat screw driver will help to open the clipped sides of the case. Do not apply too much force, so that the case won't get broken.
Study the way the case is fixed in other to get it opened. Also, remove all peripherals and the the case will successfully be removed.
Its not necessary to open the screen part. But you can do so if you like.
Good luck.
Itronix GoBook... | Answered on Jul 14, 2010
Remove the CMOS battery from you system. Be careful, the system should be turned off before doing this.
Reinsert the battery, and the password as well as the user will be reset.
-rate if it helped you.
Itronix GoBook... | Answered on Apr 09, 2010
Hard Drive: 2.5′ 40GB or 80GB Parallel ATA
Itronix GoBook... | Answered on Mar 31, 2010
Go-Daddy and others provide a basic website reasonably. Google "setting up a website" and you will find many. Good luck!
Itronix GoBook... | Answered on Mar 14, 2010
Hi:
I am reasonably sure that the hard drive accessed thru the battery compartment. You remove teh battery cover, remove the battery, and the hard drive is then able to be removed.
Itronix GoBook... | Answered on Nov 06, 2009
Computers & Internet Logo
35 questions posted
Top Itronix Computers & Internet Experts
Lee Hodgson
Lee Hodgson
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Itronix Computers & Internet
Most Popular Question
load windows 7 from flash drive gobook
  • Computers & Internet
