20 Most Recent
LG DVD 5083 DVD Player Questions & Answers
I have the 5083 dvd player, but it only seems to
The Country Code is just related to the Subtitles etc and nothing to do with the Region.
Most DVD Players/Recorders are set to Play the Region of DVD from the Country they were purchased from. Only some are Region Free (will play DVDs from any Country) when purchased.
Some DVD Players/Recorders can be changed to Region Free by simply entering a code on the Remotes handset or by following instructions to enter a Service Menu and change it their.
Unfortunately yours can only be changed by updating the Firwmare which is a risky and difficult process even if you know what you're doing. I wouldn't advise anyone to try it without previous experience as you could render your DVD Player/Recorder useless.
All discs are ejected with
This is due to following possibilities:
1. the lens of the DVD player is dusty, need cleaning or
2. due to laser lens gone faulty need replacement
hope it helps
good luck
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
