20 Most Recent
LG Electronic LRA516 DVD Recorder Questions & Answers
How to play blue ray
Unless it is specified as being able to play Blu-Ray discs, it cannot do so, and there are no 'hacks' to enable this function as the HT 554 is a DVD player/home theatre system. You would require a Blu-Ray player to play both types of disc.
Is there an unlock sequence available for the LG
1. Turn on DVD player
2. Press eject to open disc tray
3. Enter 0000 on remote
4. Region code and edit box should now be displayed on DVD player
5. Enter 0 (for all regions) in the region edit box
6. Press enter
7. Power off for a few seconds
8. Repeat steps 1- 4 if you want to check new code
How do I program a Philips Universal Remote to
The only code I could find was 0392. Press and hold the setup button until the red indicator light stays on, then release the setup button. Press the desired button in your case it would be VCR/ DVD. The red indicator light should blink then stay lit. Enter the four digit code 0392. If it was a valid code the indicator light should go off. It should work if its a good code.
LG LRA-750 goes to PAUSE during playback.
Hi Andy12345,
It sound like the LRA-750 processor board has developed a fault, it may be in its remote IR sensor circuit or the main micro-controller. If it's still under warranty I'd take it back the the store where you purchased it and get it exchanged. Some LG items have a warranty of up to 3 years, check yours on-line, at the LG website.
Regards,
Spare head 2
DVD player area code.
1. turn it on.
2. open disc tray
3. pause and press 314159
4. the player shows the actual region and a field to enter a new one.
5. enter new region. (0 for region free)
6. pause
7. Play
Lg lra-850
The program is protected from copying.
It is possible a synch restoral box such as the Optex Video Stabilizer could help in series with the video IN (composite video only) Mine is model # VO760, an old one.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
