20 Most Recent
Marantz PV-6071 60 in. Rear Projection Television Questions & Answers
Colors out of alignment
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Marantz UD5007 blinking red light then switch itself off
A Marantz UD5007 blinking a red light and then switching itself off may signal a fault or error. It could be due to overheating, disc reading issues, or technical malfunctions. Refer to the user manual for troubleshooting or contact Marantz customer support for help.
11/5/2023 3:57:10 PM •
Marantz...
Answered
on Nov 05, 2023
Marantz Cr401/N1S constantly clicks after power surge/outage.
This can depend on what the player is actually worth. A more expensive player is worth getting a price for the repair. For a more basic, budget machine it often cheaper to just replace it. Your description suggests it is some sort of issue with the disc motor or the lens motor. You will need to get a professional repairer to look at this.
8/4/2023 4:41:45 PM •
Marantz...
Answered
on Aug 04, 2023
Maranta sr6013. Volume will not go past 85.
Make certain DRC (night mode, or whatever your specific model calls it) is OFF, and Make sure that Audyssey Dynamic Volume is OFF and Audyssey Dynamic EQ is ON!
The Dynamic Volume being ON is the most common cause of what you describe, as is directly limits the peak.
4/21/2019 3:15:50 PM •
Marantz...
Answered
on Apr 21, 2019
