20 Most Recent Marantz CC-4000 5-Disc CD Changer Questions & Answers
Ive found with the AS655 Ive been working on,the lights will come on after about2-5 mins of use.this isnt a fix,just a comment.
Marantz CC-4000... | Answered on Jul 21, 2010
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Marantz CC-4000... | Answered on Dec 06, 2009
If the sound test revealed no response from the left front speaker, it is likely that there is no left channel output from your Marantz receiver. Connect a substitute speaker to left channel output to be sure.
Marantz Audio... | Answered on Dec 03, 2019
Try plugging in headphones, if they work, it sounds like outputs have blown,
Marantz Audio... | Answered on Oct 28, 2019
A high quality fast response Servo Stabilizer will solve the problem but mark my words highlighted
Marantz Audio... | Answered on Sep 23, 2019
Order the manual directly from Marantz.
Marantz Audio... | Answered on Jun 27, 2019
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Marantz Audio... | Answered on Jun 12, 2019
Hello Meredith, for what you are saying, you could have a problem in the cable that you use to send the signal you want to record, or the microphone cable or the line cable
put to record the Marantz, without any cable connected to the inputs and listen with the headphones, if the hum is, if not, try to change the cables for others of the same type, if you use microphone, controls the connectors, which do not have humidity or rust in the contacts
I hope you can solve the problem
Greetings Franco Dosil
Hola Meredith, por lo que comentas, podrias tener un problema en el cable que utilizas para enviar la se?al que quieres grabar, o el cable de micr?fono o el cable de linea
pon a grabar el Marantz, sin ning?n cable conectado en las entradas y escucha con los auriculares, si el zumbido esta, si no esta, prueba cambiar los cables por otros del mismo tipo, si usas micr?fono, controla los conectores, que no tengan humedad u oxido en los contactos
Espero que puedas resolver el problema
Saludos Franco Dosil
https://www.hifiengine.com/hfe_downloads/index.php?marantz/marantz_pmd201_221_en.pdf
Marantz Audio... | Answered on May 22, 2019
Hello Fernando, for what you say, your team has problems in the power output stage, the sound does not come out because there is a relay that is not activated as a result of that failure
If you have technical knowledge to review it, I send you the link so you can download the service manual, but go to a specialized technical service
Hola Fernando, por lo que cuentas, tu equipo tiene problemas en la etapa de salida de potencia, el sonido no sale porque hay un rele que no esta activado a consecuencia de esa falla
si tienes conocimientos tecnicos como para revisarlo, te envio el link para que puedas descargar el manual de servicio, sino dirigerete a u servicio tecnico especializado
http://www.go-gddq.com/upload/2014-10/14100413443414.pdf
Marantz Audio... | Answered on Apr 30, 2019
Hello Alessandro, if you have changed the three belts, it is very possible that the belt of the capstan, has been mounted on the edge of the motor pulley, which has a diameter may, therefore it will be faster the speed of the tape
Re-disassemble and observe the location of this belt, verify that it has the same thickness as the original, also observe that the capstan are with their bushings well, clean well the surfaces where the belts work with Isopropyl alcohol
If you have checked everything and do not find problems, you should adjust the speed of the motor, preferably with a 3 kHz cassette and a frequency meter or with an original, that you know the content
I sent you the link to download the service manual
Hola Alessandro, si le has cambiado las tres correas,es muy posible que la correa del capstan, se haya montado sobre el borde de la polea del motor, que tiene un diametro mayos, por lo tanto va a estar mas rapida la velocidad de la cinta
Vuelve a desarmar y observa la ubicacion de esta correa, verifica que tenga el mismo espesor que la original, tambien observa que los capstan esten con sus bujes bien, limpia bien las superficies donde trabajan las correas con alcohol Isopropilico
Si has revisado todo y no encuentras problemas, deberas ajustar la velocidad del motor, preferentemente con un cassette de 3 khz y un frecuencimetro o con un original, que conozcas el contenido
Te envio el link para que descargues el manual de servicio
espero que puedas resolver el problema
https://data2.manualslib.com/pdf5/111/11042/1104156-marantz/cp430.pdf?97bb3b8270b593cd10eab88f1605db6e&take=binary
Marantz CC-4000 5-Disc CD Changer Logo
Popular Tags
4 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
philips as655 no display graphics tuner
  • Audio Players & Recorders
