20 Most Recent
Marantz ZS5300 6-Channel Amplifier Questions & Answers
Marantz PM4000 amp keeps cutting out
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Volume
Depends what's up with it!
For example if it has been broken then it will have be replaced.
If it is crackling or cutting out when you move it up or down, then some dirt or wear of the contacts is causing the problem. This can be cured sometimes with a spray of Servisol Switch Cleaner (Video 40 is the best) often used to clean VHS video heads. Spray it directly into the tracks of the control, for best results and move the volume control around (no power).
You can get it from several places such as Maplin (UK) or Radio Shack (USA). Even seen it on Amazon.
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them. This is what they tried to get people to by them. I was never a fan of this system as the sound quality was never better than listening to FM radio. There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into. This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash. All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs. Problem is, the sound quality was only as good as FM radio. A pretty poor way of getting CDs into cars. But they sold millions of these things. If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected. if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around. Good luck. If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Radio channel coming through on cd zone
Sounds like an internal prob within the reciever, since recievers have radio tuners in em, maybe a prob in the input switching in it.
I assume you are running unbalanced rca cables out of the dvd player into the reciever as it probably doesn't have balanced input capability, unbalanced lines are susceptible to R.F.I. ( radio frequency interference ) but I doubt if that's the problem here unless maybe you are running very long cable lengths from the dvd player to the reciever.
Try using a different input and see if the problems still there, can use any input other than phonograph really as they are all line level inputs.
Marantz CD5004 tray keeps opening problem
CD/DVD players use a protocol;
Open tray. Insert disk. Tray switch tells mechacon that the tray is shut. Attempt to focus on disk.
If focus is acheived, then it will spin up and try to read the disk otherwise it will ask for a readable disk.
If the tray keeps opening, I would suspect the tray detect switch is malfunctioning, maybe the drive belt has stretched.
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
The poweramp of my Marantz SR6004 AV Surrount Receiver only turns on after about 3 minutes.
Parece que el problema puede estar relacionado con la fuente de alimentaci?n de su dispositivo. Es posible que desee verificar si la fuente de alimentaci?n proporciona el voltaje y el amperaje correctos. Adem?s, es posible que desee verificar si hay conexiones sueltas que puedan estar causando una interrupci?n en la fuente de alimentaci?n. Tambi?n puede intentar restablecer el dispositivo a su configuraci?n de f?brica para ver si eso resuelve el problema. Si estas sugerencias no funcionan, es posible que deba consultar el manual para obtener pasos de soluci?n de problemas m?s detallados o ponerse en contacto con un t?cnico calificado para obtener ayuda.
Marantz DV 9500 DOES NOT PLAY ANY of normal CDs. Reads ONLY Super Audio CDs. What could be the cause for this fault?
- Hardware issue: The CD player may have a hardware issue, such as a damaged laser or faulty electronics, that is preventing it from reading normal CDs.
- Firmware issue: The CD player's firmware, which is the software that controls the device, may be outdated or corrupt, causing it to only read Super Audio CDs.
- Compatibility issue: The CD player may not be compatible with normal CDs, and is only able to read Super Audio CDs due to their specialized format.
In terms of adjusting the laser pick-up, it is generally not recommended to try to adjust the laser pick-up yourself, as it can be a delicate process that requires specialized equipment and knowledge. If you believe the issue may be related to the laser pick-up or other hardware, it may be necessary to seek the assistance of a qualified technician or the manufacturer.
If the CD player is unable to read the content of a normal CD and is returning to 00:00 tracks on the display, it is possible that the issue may be related to the laser pick-up or other hardware. It is also possible that the issue may be related to internal ICs or other electronics, in which case it may be necessary to diagnose the issue further to determine the cause and find a solution.
Marantz sr18 sound goes out
NOT A CAR/TRUCK SO MOVED TO AVR
THE AVG. AVR HAS OVERLOAD DETECTOR AND LAMP AND RELAY
THAT FAILS WHEN OVERLOADED.
PER THIS SIMPLE LIST
- SPEAKER WIRES SHORTED.ENDTO END
- SPEAKER SHORTED.
- TOO MANY SPEAKERS WIRED IN PARALLEL.(THE ohms rule violated)]
- the amps side is failing.
- the overload detector is bad, telling lies, and shutting it down.
- try no speakers, to see if it trips.
- It is 1999 and is old. even bad caps inside now.
only does
Digital inputs: coaxial, optical
Video Connections: component, composite, SVHS
the rig has fan sensor failure and over temp too, and the service manual covers that.
see protector DRIVE here, it shuts down all outputs via relays.
free to read and DL.
https://www.manualslib.com/manual/1066247/Marantz-Sr-18-U.html?page=6#manual
