20 Most Recent
Metrologic Instruments 9520 Voyager Questions & Answers
Ms9520 won't send info to computer, shuts down my keyboard
Sounds like something is plugged in wrong or when you were moving it something came ajar. Sometimes cards in memory slot, pci slots or pcie slots come ajar when moving. Open desktop and inspect all your cards in their slots You will see what I am talking about if you open it up.
even if one of the cards is a tad crooked it will act like you are saying, it shuts down to protect itself and sometimes it is too late. Just push down on all the cards in slots to make sure they are firmly in place. See what happens.
12/30/2017 10:24:59 AM •
Metrologic...
Answered
on Dec 30, 2017
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more)
The scanner has probably not been set up correctly as this is a common issue.
the settings need to be set correctly for your environment.
you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner,
There is an option to recall defaults
here is the electronic manual
ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
My scanner reads only12 numbers
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
We have the barcodes to scan to emulate the keyboa...
Without knowing your application or scanner programming I can't be certain but it sounds like the scanner may be reading information on the code that you want parsed out. Check with whomever labels the units to find out exactly what is in the barcode (it's possible the "35 S " is not encoded) and then determine what you need to send to the program you are scanning the information in to. The scanner can be programed to pass along only specific characters that were scanned (i.e. the 13048) and to pre-pend or append additional characters as well (i.e. 35 S ). You'll need the scanner's programming manual to do that. Here's a link to the scanner's programming manual. Choose the first User's Guide on the list:
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=297Good Luck!
Barcode font problem
Try going to the manual and scanning the setup code for accepting a the I2of5 code.
Drivers for metrologic ms9500 vpyager
All the serial drivers and utilities are available for download from Honeywell.com the company that owns the line. Assuming you Voyager is either the 9520/9540 model follow the link below and you will have access to all the relevant software for your device.
Hope this helps FixYa,
Chris
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Metrologic MS9520
You can reset back to original setting using your manual. If you are using cash register you need to look for the right settings in order the scanner will working.
Rate me SOLVED
Voyager 9520 10 digit UPC
The last digit should be a parity Digit (used for error checking)
you may be able to clear this using the settings barcodes in the user manual
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
