20 Most Recent Canon PIXMA MX860 All-In-One InkJet Printer Questions & Answers
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Canon PIXMA... | Answered on Feb 21, 2019
problem on power supply
Canon PIXMA... | Answered on Sep 09, 2016
On which copier? If it's kyocera mita then it's the brakeage of the heater thermo fuse.....or your electricity current.
Canon PIXMA... | Answered on Apr 23, 2016
Hi!
When you say that you went through the cleaning process, did you use the Canon Utility to clean the print heads?
I'd try that-- feel free to reply to this post should you need any additional assistance.
I've also attached the support page directly from Canon for your model printer.
Canon Support Drivers PIXMA MX860
Hope this helps!
Canon PIXMA... | Answered on Jun 15, 2015
When printing from computer set the paper default to High Resolution paper....When copying set the paper default to photo paper plus glossy II. it may work with other settings but have tried it yet.
Canon PIXMA... | Answered on Jun 09, 2015
Sounds interesting! Uninstall the printer and all it's utilities from your pc. Sounds as there might be a bit of corruption in the print driver. Try a roll back of your o/s to a time when it was printing correctly. Then do a disk cleanup, a defrag. Have a restart of your system and then reinstall the software the printer
The roll back/recovery might clear any issues that have happened since all was working correctly. The disk cleanup will clear all the junk on the machine that is extraneous. The defrag should put all files into locations where their contiguity ensures you have a smoothly functioning machine. It may also overwrite some of the
faulty software belonging to the old installation of the printer
Sounds like a fine plan, and it should work.
Canon PIXMA... | Answered on May 31, 2015
How do I fix "ink absorber full" on my MX860?
Canon PIXMA... | Answered on Mar 10, 2015
Key Menu, then tools or setup [OK],
from maintenance - arrow key left or right to device settings [OK]
arrow down to user settings [OK]
That should put you into the menus for changing date, time etc. You should also check your daylight saving and locationsettings while you're in there
When done use the back arrow to step all the way back out.
Canon PIXMA... | Answered on Mar 02, 2015
Hello
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer.
If you have already done all this then I suspect that you will need to find out more about the error. You can download various manuals for your machine from here:-
Canon PIXMA MX860
This may give you some idea of the more common errors and how to fix them. If this doesn't work then the ultimate thing to do is to remove the printer and its drivers from the computer and reload the drivers from the disks supplied with the printer.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Canon PIXMA... | Answered on Feb 27, 2015
Anonymous,...This is a critical warning from the printer since when the printer detects the waste ink absorber is full it will shut the printer down. What Canon wants you to do is to bring the printer into their Service Facility and have it totally cleaned. The labor for this and the new parts required will cost much more than a new printer,..and therefore you will buy a new printer. However if you have the time and skill my Repair Manual will instruct you how to do all of this yourself. You can reach me at bud4golfatattdotnet.
Canon PIXMA... | Answered on Feb 17, 2015
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Canon PIXMA... | Answered on Jan 16, 2015
Canon has changed all of the new printers and eliminated the built in reset ability of the printer. You must have specific software to access the Service Mode and from there you can reset the waste ink counter. Contact me at [email protected] for detail
Canon PIXMA... | Answered on Jan 09, 2015
No. The fault will be with either the mains cable/plug/socket on wall.
The power supply in the machine (its a sealed unit) or the SCNT Board. Its unlikely to be the operation panels on/off switch.
When you try to turn the machine on, listen to it. Do you hear a buzz or in fact any sound at all? If you do then it will be the board. If you don't then its more than likely the power supply. Also look at the screen, do you have any black squares on it? If so then again its the board.
Canon PIXMA... | Answered on Jun 29, 2014
Canon PIXMA MX860 All-In-One InkJet Printer Logo
136 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
in regard no printing black canon mx860
  • Office Equipment & Supplies
