20 Most Recent
Metrologic Instruments MS 7120 ORBIT (MK712032A08) Questions & Answers
I need a driver for MK6520-31A08
OK my friend... after all your hard work I recommend go to this link and start reading! Pick your the program YOU think will help you most...
Now BEFORE you install ANYTHING be SURE you have *everything* important to you backed up!
These are ALL supposed to be "The BEST" FREE programs as of 12/1/17 so here you go...
11 Free Programs That Will Help Update Drivers in Windows
ALLOW the
SOFTWARE to do your hunting. Sometimes they give you IMPORTANT INFORMATION about your missing drivers! Others give you specific LINKS to them.
And others may CLAIM they FOUND
the very drivers you need and
YOU can have them too ~ for $50... no fun.
A final note... Be sure the drivers you select and install are compatible with your XP Operating System (
32-Bit I suspect).
Best of luck fishing!
Anthony
The scale doble scanner ,
u need to caliberate it,, the scanner manual has a bunch of bar codes in it,, this will caliberate the scanner to recgonise your bar codes that you are using.. There are different types of bar codes.. follow the instructions in your manual to caliberate it.. If you dont have the manual one can be downloaded from the manufactures web page..
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
