20 Most Recent Metrologic Instruments Voyager MS9520 Handheld Questions & Answers
Where can I get a driver for a Metrologic
www.honeywellaidc.com
1/1/2016 10:27:05 AM • Metrologic... • Answered on Jan 01, 2016
Metrologic ms9520 not scanning UPC's
Hello.The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code. You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40Hope this helps!
11/9/2013 9:35:35 AM • Metrologic... • Answered on Nov 09, 2013
Dear Sir i want the driver
HelloYou can find all available drivers for this scan gun at the following site:http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40Hope this helps!
11/9/2013 9:31:30 AM • Metrologic... • Answered on Nov 09, 2013
Cable pinout rs232
HelloSorry to hear about the cable damage on your scan gun. Below is a link for the manual for your gun. Page 38 and 39 has the cable pin-out diagram to help you with re-wiring the cable.http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0CCkQFjAA&url=http%3A%2F%2Fwww.jrdrucksysteme.de%2Fuploads%2Fmedia%2FBedienungsanleitung-Honeywell-Metrologic-MS9520-MS9540.pdf&ei=UPt9Uu_GOMTnkAeR4IHwBw&usg=AFQjCNHP1SHKR3jF0Sgo8Vpj3YpexFyKTg&bvm=bv.56146854,d.eW0Hope this helps!
11/9/2013 9:11:02 AM • Metrologic... • Answered on Nov 09, 2013
0answers
0answers
0answers
Hi, I need user's guide of MS9520
Here is a link to a web site that has your manual in PDF format.
http://www.taltech.com/TALtech_web/support/Manuals.html
10/23/2009 2:17:49 PM • Metrologic... • Answered on Oct 23, 2009
Scanner comes back online when you unplug and
call 1800-582-4263...Metrologic was bought by Honeywell -- that's the new number - ask to be put through to Tech Support.
Cheers..
Billy Barcode
8/5/2009 2:20:40 PM • Metrologic... • Answered on Aug 05, 2009
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
4/2/2009 1:11:20 AM • Metrologic... • Answered on Apr 02, 2009
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
4/2/2009 12:29:32 AM • Metrologic... • Answered on Apr 02, 2009
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
4/2/2009 12:27:26 AM • Metrologic... • Answered on Apr 02, 2009
I need a driver for MK6520-31A08
OK my friend... after all your hard work I recommend go to this link and start reading! Pick your the program YOU think will help you most... Now BEFORE you install ANYTHING be SURE you have *everything* important to you backed up! These are ALL supposed to be "The BEST" FREE programs as of 12/1/17 so here you go... 11 Free Programs That Will Help Update Drivers in Windows ALLOW the SOFTWARE to do your hunting. Sometimes they give you IMPORTANT INFORMATION about your missing drivers! Others give you specific LINKS to them. And others may CLAIM they FOUND the very drivers you need and YOU can have them too ~ for $50... no fun. A final note... Be sure the drivers you select and install are compatible with your XP Operating System (32-Bit I suspect). Best of luck fishing! Anthony
12/2/2017 2:40:38 PM • Metrologic... • Answered on Dec 02, 2017
I Have IS4120 barcode scanner,
Go to manufacturer web site for this information.
8/31/2017 8:56:58 PM • Metrologic... • Answered on Aug 31, 2017
0answers
Metrologic Instruments Voyager MS9520 Handheld Logo
24 questions posted
Top Metrologic Instruments Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Metrologic Instruments Computers & Internet
Most Popular Question
locked metrologic ms9520 37 keyboard
  • Computers & Internet
