20 Most Recent
Fisher and Paykel DD24DCFX6 Dishwasher Questions & Answers
My dishwasher DW60CSX1 is approx
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error.
Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
1/2/2023 2:31:37 AM •
Fisher...
Answered
on Jan 02, 2023
Hi, how do I fix error code F1 of a fisher & paykel draw dishwasher??
The F1 error on a Fisher and Paykel dishwasher means the flood switch was activated for seven seconds or longer. ... The dishwasher's flood switch could activate because the water is leaking around the heater plate. It would still eventually show up somewhere, though a leak like that would kill the heater plate too.
11/5/2018 12:49:46 AM •
Fisher...
Answered
on Nov 05, 2018
