20 Most Recent Mpio HD-300 MP3 Player Questions & Answers
WONT PLAY KNOW MUSIC
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
9/29/2009 7:48:04 AM • Mpio HD-300 MP3... • Answered on Sep 29, 2009
2answers
MY Mpio wont show movies
12/10/2008 6:33:46 AM • Mpio HD-300 MP3... • Answered on Dec 10, 2008
My mp3 player froze
I realized there was a "reset" button and it worked after that.
11/25/2008 2:44:36 PM • Mpio HD-300 MP3... • Answered on Nov 25, 2008
BRAND NEW MPIO HD300 Completely DOA!
It's a reasonably straightforward task. There are 2 screws at either side (near the top) of the player. You'll need a small Alan-key to remove these. Once this is done, carefully prise off the back cover and you'll be able to see the battery - at the back. Just un-clip the battery cable. - You might want to check the connection in the first instance, if however, the battery needs replacing see replacment battery model number below: -
UP325385A4H-UP325385A5H
Hope this heps
Nam1
3/16/2008 11:34:10 AM • Mpio HD-300 MP3... • Answered on Mar 16, 2008
MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
3/9/2008 9:51:29 AM • Mpio HD-300 MP3... • Answered on Mar 09, 2008
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
3/8/2008 7:08:02 PM • Mpio HD-300 MP3... • Answered on Mar 08, 2008
Try to reformat using your USB 2.O, with The Super-Reboot MP3 Software, may take up to 24/48 Hours to Reformat
2/28/2008 11:38:50 PM • Mpio HD-300 MP3... • Answered on Feb 28, 2008
Frozen - Mpio HD-300 MP3 Player Problem
Sounds like the player can't see it's hard drive, not much you can do if the drive is dead. If it's under warranty then have it fixed.
1/21/2008 6:48:29 PM • Mpio HD-300 MP3... • Answered on Jan 21, 2008
My Mpio HD-300 MP3 will not sync to Windows Media Player
www.mpioamerica.com has all the software that was on the CD.
you can try Mpio.com as well
12/21/2007 8:26:14 PM • Mpio HD-300 MP3... • Answered on Dec 21, 2007
Mp3 player repair
Hi
It's called the FPC cable, you can try to connect Mpio America
[email protected]
12/21/2007 8:25:22 PM • Mpio HD-300 MP3... • Answered on Dec 21, 2007
0answers
MPO-I-FY900(B)
Be the first to answer 9/17/2013 9:33:28 AM • Mpio Audio... • Posted on Sep 17, 2013Be the first to answer
0answers
Hi, I can no longer browse through the files of my MPIO MG 100.
ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
9/27/2009 2:47:46 AM • Mpio Audio... • Answered on Sep 27, 2009
Hmm...well wnhen ever i charge
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
7/5/2008 9:08:04 PM • Mpio Audio... • Answered on Jul 05, 2008
How to disassemble mx5020 speaker?
Greetings, Please check the handbook of your device to see if there are diagrams highlighting the location of the screws for the speakers. Once located, you can start by using a screwdriver to remove those screws and open up the device. Otherwise, you might need to work with an electrician or possibly a pawnshop to help get the device open. Thank you.
3/27/2023 6:57:30 PM • Audio Players &... • Answered Yesterday
2answers
I bought a PSWi-8M wireless
Unfortunately you need the transmitter. i would contact Polk and see if they sell this part separately or start scouring the internet. someone might have blown their sub but the transmitter would still work.
3/25/2023 8:46:19 PM • Audio Players &... • Answered 3 days ago
Motorola DCP-501 All-In-One Home Theater Receiver will not come on at all?
Check the power source and if you can get behind the switch, check for continuity. Make sure that the device is properly connected to a power source and that the outlet is functioning. You can test the outlet by plugging in another device. Check the power cable and make sure that the power cable is properly connected to the unit and the power source. Also, check for any damage or fraying on the cable. Check the power switch to ensure that the power switch is turned on. It is possible that it might have been turned off accidentally. Try resetting the device by disconnecting it from the power source, waiting for a few minutes, and then plugging it back in. If all those fail, you will need to take to an audio engineer.
3/25/2023 3:52:19 AM • Audio Players &... • Answered on Mar 25, 2023
Need manual for Micronta 63-712 world time
3/24/2023 6:59:55 PM • Audio Players &... • Answered on Mar 24, 2023
Mpio HD-300 MP3 Player Logo
Popular Tags
14 questions posted
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mpio Audio Players & Recorders
Most Popular Question
wont play know music
  • Audio Players & Recorders
