20 Most Recent LG 32LD350 32 in. LCD TV Questions & Answers
Every weight trainer and bodybuilder for you to know the way to build muscle mass. Building more muscle size could be the goal of anyone trying to enhance their muscularity. Even people who just weight a tid bit are looking to build muscle to add shape to their bodies and lift their resting metabolism they can get rid of unwanted body a lot of fat. It may take some time, but anybody can learn the right way to build muscular quickly.
http://testosteroneboosterreview.net/testadrox/
LG 32LD350 32... | Answered on May 18, 2016
Sounds like a problem with the remote where a function button on the remote is being pressed for a function which is not on the TV. Could be a fault in the remote or moisture or some other foreign body which has gotten into the remote. Try removing the batteries from the remote or covering the infra red receiver sensor on the TV. Hopefully this will stop it. It may alternatively be some other infra red source which is confusing the TV. The TV generally won't have unavailable functions in its own menu so it's most likely the remote. Hope this helps
LG 32LD350 32... | Answered on Apr 24, 2016
Hi janice,
You probably have damaged the earphone jack. Please have it checked.
LG 32LD350 32... | Answered on May 31, 2015
Try just pressing a chanel number button, some tv's only turn off with the power button and to power them on you press either the chanel up or down button or one any of the number buttons on the remote
LG 32LD350 32... | Answered on Dec 30, 2014
There's no reason. The two things are not connected. Make sure you have the TV on the digital tuner, and not the analogue one.
LG 32LD350 32... | Answered on Sep 07, 2014
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
LG 32LD350 32... | Answered on Apr 18, 2014
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
LG 32LD350 32... | Answered on Nov 10, 2013
goto channel preset
put auto search
it will scan all channels & save.
LG 32LD350 32... | Answered on Aug 27, 2013
For more details, check its user manual.
LG 32LD350 32... | Answered on May 23, 2013
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
LG 32LD350 32... | Answered on May 05, 2013
LG 32LD350 32 in. LCD TV Logo
94 questions posted
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
View Most Popular
  • LG Televison & Video
Most Popular Question
function not available sign keeps coming
  • Televison & Video
