20 Most Recent Mackie 2404-VLZ3 Mixer Questions & Answers
It sounds like you're new to 'professional' mixers. You would NEVER normally use an aux for effects. Any effects will normally be inserted in the sound chain using an insert. You have a pair of group inserts if you are wanting to apply an effect to the output (these are after the mix) and would typically be used for master de-essers or possibly compressor limiters or maybe even an equaliser, it would not be sensible to use an effect like a delay/reverb here.
I would have expected you to be using the group outs for the monitor mixes and am not sure what you may be using them for otherwise. If you used these you would free up 4 of the Aux outs for a 'multi channel' reverb/echos which you could take back into other channels and back into the main mix.
What is it you are tyring to achieve?
Mackie 2404-VLZ3... | Answered on May 17, 2014
Upon opening the mixer, you might find that the preamp boards are
similar , use the running board as a guide in troubleshooting .
On most are the XLR inputs with phantom supply.
Mackie 2404-VLZ3... | Answered on Oct 02, 2012
you need a recording device to do it, a recording software and most of all an
interface.
you can find it here page 7 on your Owner's Manual
Owner's Manual
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
downloads.mackie.com load this bus driver file. use winzip to install.....have fun meder's tv service
Mackie 2404-VLZ3... | Answered on Aug 28, 2012
Without more information of your speakers and amps we can't really help you. The Mackie board puts out line-level signals and that should drive any connected amp or powered speaker to the full capability. Make sure you are using BALANCED interconnect lines either XLR or TRS cables. Use of TS unbalanced cables costs you 6 DB and also noise pickup. Make sure ALL your gear, amps, speakers etc are powered from a SINGLE receptacle or power conditioning module. Normally you will use the AUX outputs of the mixer by way of TRS cables or balanced lines in a snake to power amplifiers onstage which then connect to the stage monitors. If you have powered monitors the returns of the aux to the stage go to the powered monitors. A heavy duty extension cord brings power back from thee stage power to the mixer.
Mackie 2404-VLZ3... | Answered on Sep 07, 2011
Check the sound in the headphones... It may be your power amps are giving out. MAKE SURE the interconnect cables are either XLR or TRS cables (balanced line). Make sure your power amps and the mixer are ALL powered from the same receptacle OR power conditioner module. You cannot power the amps from one end of a building room and the mixer frrom a wall receptacle at the other end. The building ground bounce can not only cause noise, but can destroy sensitive input circuits of the equipment.
Mackie 2404-VLZ3... | Answered on Jul 10, 2011
You would connect at Aux outs of Mackie to inputs of Peavey
Mackie 2404-VLZ3... | Answered on Apr 13, 2011
Download the schematic at:
http://elektrotanya.com/mackie_1604-vlz_mixer.pdf/download.html
Scroll down to the link to download that says "Get Manual"
This is for the 1604 unit which is just a truncated version of yours. When downloaded, find the phantom power supply on page 18.
There are too many components to guess which one so best just to troubleshoot.
I would even suspect the phantom switch since they have POOR design with no inrush current limiting when charging the input capacitor. Since the 48 is not individually fused, if the inpout cap C3 shorts, it probably will take out the switch or the diodes.
Another user had the Zener D9 fail which would cause the problem. Meter the voltage across C3 (probably about 60 volts) and D9 and C4 (47 volts). First check C4 as that cap is run TOO close to the rating of 50 volts... poor design... C5 would also be suspect... or Q1 and Q2.
Then it gets dicey as there are UNDOUBTEDLY many bypass caps in the mixer portion of the board.
Mackie 2404-VLZ3... | Answered on Apr 02, 2011
Possibly you are using the audio from the subs or the Aux which are NOT controlled by the slide faders?
Sometimes users turn up the stage monitors to the point they can't control enough with the mains.
Make sure your system passes the audio to the amps from the XLR plugs for the mains on the back AND you use BALANCED lines to do so.
Mackie 2404-VLZ3... | Answered on Mar 15, 2011
You need to describe what you mean by "several points".
These mixers have sections grouped and if you lose signal as a group, I believe it is eight channels, cables MIGHT be a problem. If it is random channels, it is more likely a failure of faders if they seem noisy and cut out. A small amount of CRC226 squirted into the center of the slot and working them MIGHT restore noise free operation.
Note: One can do a lot of troubleshooting externally by analyzing the different outputs from the AUX and SUB's and headphones using the SOLO buttons, etc. First thing is to completely characterize the failures.
Mackie 2404-VLZ3... | Answered on Jan 11, 2011
check your cables, on some Mackie boards press the switch to enable master out, make sure the mute or cancle button is not pressed. i have a 2404 vlzpro mixer it's simular to yours, if you have any problems, you can call Mackie direct if the issue is not solved, it could be a bad button, fuse or slide controle, or even a fuse
Mackie 2404-VLZ3... | Answered on Dec 12, 2010
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
Mackie Music | Answered on Sep 27, 2019
Here you go
http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf
This link to the manual is on the Mackie website
Mackie Onyx 32 4
Mackie Music | Answered on Jun 08, 2019
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
Mackie Music | Answered on May 03, 2019
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
Mackie 2404-VLZ3 Mixer Logo
16 questions posted
Top Mackie Music Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
peavey xr8300 want use
  • Music
