20 Most Recent Gemini Sound Products Gemini Cdmp-6000 Dual Cd/mp3/usb & Mixer Co-ships Free Questions & Answers
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Gemini Sound... | Answered on Jul 14, 2015
I have same problem
Gemini Sound... | Answered on Mar 06, 2014
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Gemini Sound... | Answered on Nov 03, 2011
Hi mreuten44,
If the unit won't play or read disc, it is often caused by the lens. The easiest way to correct this problem is as simple as the lens may need cleaning. Here are several troubleshooting steps that you can take:
1. Remove excess dust from the CD player. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
2. Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
3. Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
4. Make sure the slider that the lens is attached to is all the way back to the platter.
5. Check the platter, it may have slipped down to close to the lens and it wont focus.
6. If the above steps did not work, the motor drive circuit is defective. At this point you need a help of a repairman to check the unit.
Hope it helps.
Thank you for using FixYa.
Gemini Sound... | Answered on Jun 21, 2011
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Gemini Sound... | Answered on Nov 27, 2010
One of the first things a technician does with a voltmeter it to check 'all the voltages' in a system are correct..
Even without a specific circuit diagram for the board, 'Applications Notes' for chips and seminconductors will give nominal expected voltages in a working circuit.
Remember you can burn out the meter by connecting it to any source of current when on the Ampere or Ohm settings.
Technicians usially start at a high (highest) Voltage range setting and work downwards..
Providing the maximum Voltage is not exceeded on any range, whether it is AC or DC will not damage the meter.
'Fluke' by the way are a 'top end' professional product - check the price ;)
Gemini Sound... | Answered on Nov 30, 2014
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered on Feb 18, 2020
See https://www.diyaudio.com/forums/multi-way/99647-magnavox-horn-specs.html
Music | Answered on Feb 09, 2020
For what it's worth, the Style AA was advertised in 1910 catalogs. I believe they continue to have been made for forty or so years after that. So any time between 1909 (when pianos started being labelled 'Behr Bros') through to around 1950 or so ,,,
You can see the catalog https://antiquepianoshop.com/online-museum/behr-brothers/#berh2
Zager yes, but Salisbury Cathedral is a church in Hampshire UK
https://www.google.com/search?q=Is+Salisbury+Cathedral%2F+Zager+Guitars+legit
Music | Answered on Jan 16, 2020
go to www.reliable-store.com you will get it there
Music | Answered on Jan 09, 2020
Gemini Sound Products Gemini Cdmp-6000 Dual Cd/mp3/usb & Mixer Co-ships Free Logo
Popular Tags
11 questions posted
Top Gemini Sound Products Music Experts
Colin Stickland
Colin Stickland
rhodesworks
Vuk B
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Sound Products Music
Most Popular Question
gemini cdmp 6000 cue button stuck will
  • Music
