20 Most Recent Behringer Xenyx 2222fx Premium 22 Input 2/2 Bus Mixer Questions & Answers
The Phantom power comes from a seperate winding on the switching power supply.Likely one or more of the other voltages are not present due to a failure of one or more components. The supplies are current limited so a short anyplace on the board may cause the problem. I had one of these short betwen the +/- 15 volt busses because somebody spilled liquid into it.
Here is a close schematic... a slightly different model with less channels, but circuoitry is the same, just more copies of it in yours: I believe it is zipped with four files... the last is the power supply.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Behringer Xenyx... | Answered on Jan 20, 2019
This is likely a pwer supply problem... BUT do check that the power cord is properly seated... pretty common that these work loose.
Behringer Xenyx... | Answered on Jul 21, 2011
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Behringer Xenyx... | Answered on Jul 11, 2011
Why did you change the fuse? If it was blown, then power supply has failed. Here is your schematic. The power supply is on page 14.
http://elektrotanya.com/behringer_ub-2222fx-pro.pdf/download.html
Scroll down the page at the site to the "Get Manual" Click on that to download the schematic. When working on line operated supplies use an isolation transformer for personal safety. The regulator chip IC2 has probably failed but test before changing. HINT: When restoring the supply, put a 60 watt light bulb in series with the hot power lead to act as a resetable fuse... saves fuses and also other components if all the bad parts haven't been weeded out.
Behringer Xenyx... | Answered on May 11, 2011
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Behringer Xenyx... | Answered on Feb 27, 2011
There is a problem with the internal circuitry. There may be one of more components that have failed or weakened.
Behringer Music | Answered on Jan 06, 2021
$95 an hour! seriously i don't know why more people haven't tried this, i work two shifts, 2 hours in the day and 2 in the evening...and whats awesome is im working from home so i get more time with my kids. heres where i went Copy Here........EARN75.com
Behringer Music | Answered on Dec 24, 2020
Radio Shack may have the fans or can order it for you take the fan to a local Radio Shack store.
Behringer Music | Answered on Dec 14, 2020
In order to help you we would need the make and model of the mixer.
Behringer Music | Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music | Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music | Answered on Oct 23, 2019
You have given in detail which is helpful
Behringer Music | Answered on Oct 16, 2019
Behringer Xenyx 2222fx Premium 22 Input 2/2 Bus Mixer Logo
7 questions posted
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
no power cord tested ok
  • Music
