20 Most Recent Allen & Heath Xone-22 2 Channel Dj Mixer Questions & Answers
Does the left meter do the same thing? If the meter matches the right one, I would suspect the volume potentiometer on the powered speaker. Try exercising the volume knob. There might be some oxidizing on the potentiometer.
Allen & Heath... | Answered on Oct 25, 2017
If this is stopping when you grab a connector then you have a bad solder on the connector. a short or break in the wire or a ground is bad.
Allen & Heath... | Answered on Apr 07, 2016
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Allen & Heath... | Answered on Apr 11, 2011
Usually this problem happens due to bulging of filter capacitors in the Power Supply Unit. identify and replace faulty capacitors with higher voltage ratings to fix this problem. Replacement of the capacitors is very easy if you have repair experience or at least soldering experience.
Allen & Heath... | Answered on Jan 27, 2019
cachepe.samedaymusic.com/.../gl2400ug_ap5597_2-42fad5e2de1bc79db38576be174464d4.pdf - United States
Above is your user manual below is a service and repair manual.
http://www.performanceaudio.com/cgi/product_view.cgi?products_id=16696
Indeed i would suspect something around your Final Output semiconductors, and any associated resistors?
You really must obtain a service manual, here there are the troubleshooting steps required to isolate and hopefully allow repair of your unit.
Look for any discolored components etc, check if any are overly hot... use a temperature probe on suspected components. Freeze spray may also be useful in diagnosis.
Use your eyes & nose to isolate the bad burnt overheated components, I sometimes use a straw up a nostril and selectively go over suspect parts, and "Sniff" to try and detect the overheated smell... it works.
http://www.allen-heath.co.uk/uk/TechnicalSupport.asp
Above is your tech support link, contact them for any info you require.
Allen & Heath... | Answered on Nov 30, 2010
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Music | Answered 4 hours ago
Contact Clavinova directly to request the manual.
Music | Answered on Nov 11, 2020
Did you get it fixed?
I have exactly the same problem!
Music | Answered on Oct 26, 2020
hi becky
from looking up the model some of the prices were only 30.00 to 40.00 dollars needing repairs other units/ models went higher in price depending on model and if they where in good repair.
so the decision for u would be is this the organ that you want to restore or do you want to look for other units?
Music | Answered on Oct 23, 2020
So I got a used one of these for free because it had the same issue.
I read about battery failure, so I opened up the piano and sure enough the battery had corroded. I also read that the battery is only necessary for the memory feature, which I don’t care too much about. I pulled out the board (super easy to do, no screws or anything, it just pops out) and took it a local electronics/tv repair guy. In about a half hour he took off the battery, fixed a bad trace on the board with a quick solder, and handed it back. $40.
Plugged it back in, bam works like a charm.
As long as there wasn’t too much damage from corrosion, a repair guy should easily be able to do what I described.
I hope this solves your (and anyone else’s) problem!
Music | Answered on Oct 06, 2020
Take it to a music shop. They should be able give you help in finding a good place.
Music | Answered on Aug 01, 2020
Allen & Heath Xone-22 2 Channel Dj Mixer Logo
8 questions posted
Top Allen & Heath Music Experts
Marvin
Marvin
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
View Most Popular
Allen & Heath Music
  • Allen & Heath Music
Most Popular Question
allen
  • Music
