20 Most Recent Behringer *new* Behringer X1222 16-input 2/2-bus 24-bit Bus Mixer Questions & Answers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Behringer *new*... | Answered on Nov 30, 2010
There is a problem with the internal circuitry. There may be one of more components that have failed or weakened.
Behringer Music | Answered on Jan 06, 2021
$95 an hour! seriously i don't know why more people haven't tried this, i work two shifts, 2 hours in the day and 2 in the evening...and whats awesome is im working from home so i get more time with my kids. heres where i went Copy Here........EARN75.com
Behringer Music | Answered on Dec 24, 2020
Radio Shack may have the fans or can order it for you take the fan to a local Radio Shack store.
Behringer Music | Answered on Dec 14, 2020
In order to help you we would need the make and model of the mixer.
Behringer Music | Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music | Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music | Answered on Oct 23, 2019
You have given in detail which is helpful
Behringer Music | Answered on Oct 16, 2019
I looked up what that unit is so I'm not uber familiar and this is before coffee, however, check your effects levels, possibly delays or echos are building up on an individual channel and adding to your total output making it clip. Even if you don't have the effects on output, they can work in the background and clip internally. Is the output sound affected? Magnetic interference is another possibility if you are running it close to pickups, recorders and other high power supplies. Trim levels set too high? I don't know your actual stage setup but these are a couple things I have experienced through the years. Ahh, here's coffee and a drink to you finding your problem.
Behringer Music | Answered on Sep 15, 2019
Behringer *new* Behringer X1222 16-input 2/2-bus 24-bit Bus Mixer Logo
Popular Tags
3 questions posted
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
connect mixer crown power base 2 amp
  • Music
