20 Most Recent Samson New Samson Mdr-1064 10 Channel Mixer [2363] Questions & Answers
Getting distorted sound when connecting
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
9/25/2011 3:30:49 PM • Samson New... • Answered on Sep 25, 2011
I have a Samson XP501i and I want to also hook up a monitor to it. I have a Samson POWERED monitor - 800 watts. Will that work? Or will it blow up my PA?
You can safely connect your powered monitor speaker to either the monitor output jacks or the tape output RCA jacks on your XP510. In addition, you may download the owner's manual here: https://www.manualslib.com/download/515708/Samson-Expedition-Xp510.html
10/31/2018 2:53:13 AM • Samson Music • Answered on Oct 31, 2018
Power schematic diagram
Which amplifier specifically?
5/4/2014 9:31:04 PM • Samson Music • Answered on May 04, 2014
0answers
L612M
Be the first to answer 3/23/2014 3:10:10 AM • Samson Music • Posted on Mar 23, 2014Be the first to answer
0answers
0answers
Samson MDR8 blowing internal power supply fuses.
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
3/17/2010 3:16:09 PM • Samson Music • Answered on Mar 17, 2010
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Samson New Samson Mdr-1064 10 Channel Mixer [2363] Logo
3 questions posted
Top Samson Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Samson Music Expert? Answer questions, earn points and help others
View Most Popular
Samson Music
  • Samson Music
Most Popular Question
getting distorted sound when connecting
  • Music
