20 Most Recent Acme Supreme Juicerator Juicer Model 6001 Questions & Answers
buy a new blade
if someone tells you they can sharpen the blade make sure the teeth are all even and the disk is rebalanced
In other words buy a new blade the juicer will work better.
BTW why do you think the blade needs replacing ???
Acme Juicers | Answered on Apr 02, 2019
check with an appliance repair shop but I suspect that it will be cheaper to junk it and get a new unit.
Acme Juicers | Answered on May 14, 2015
It seemed that when the kale got stucked it caused the juicer to either exert more power than its supposed to causing problems inside the unit.
1. Open the unit up and please check the fuse make sure that it has not blown due to possible excess electricity it received. 2.Check if the gears of the juicer are in place and that they are not damaged. 3. Using a power tester check the switch and the pc-board because some capacitors may have been damaged and those needs to be replaced as well.
If you're uncomfortable doing that then you may need the help of a local technician so they can do all the testing and the replace the parts that needs to be replaced for you.
Side note: Consider the price of getting this unit repaired and getting a new one. If the price will be half or more of what a new one would cost it would be better to let it go and get a brand new juicer.
Hope this helps!
Acme Juicers | Answered on Aug 15, 2011
Hello!
If you prefer a waring product authorized service center, there is none in your area. The closest is 46 miles away from your state.
EMR Service - 7575 Gary Drive Manassas, VA 20109 - 703-631-1575
If you prefer a non waring authorized service center within your area, you can try
Handyman Services
866-389-3076* 100 Blanche Circle, Winchester, VA 22602
American Home Shield - Home Appliance Warranties
www.HomeWarrantyService.net...
(866) 407-8317
AJ Madison, Your Appliance Authority
www.ajmadison.com...
(800) 570-3355
Acme Juicers | Answered on Jul 22, 2011
they have them on amazon.com
Acme Juicers | Answered on Mar 02, 2010
WARING AT 800 492 7464 OR COST PLUS
JUICERS AT 800 578 5939. ABOUT $30. IF
YOU ARE HANDY YOU CAN SHARPEN WITH
AN ELECTRIC DRILL AND SMALL BIT. DRILL
VERTICALLY IN TO EACH CUTTING CREVICE.
Acme Juicers | Answered on Jun 30, 2009
There should be an on button on your blender
Juicers | Answered on Jul 24, 2020
I think Cuisinart has a pretty affordable juicing line.
Juicers | Answered on Apr 22, 2020
Acme Supreme Juicerator Juicer Model 6001 Logo
3 questions posted
Top Acme Juicers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
View Most Popular
Acme Juicers
  • Acme Juicers
Most Popular Question
acme juicerator
  • Juicers
