20 Most Recent Paxar Monarch 9825 Thermal Label Printer Questions & Answers
Monarch label gun replacement parts can be easily found on amazon, click here Amazon com Monarch 1110 label gun parts and take a look. Wish you best of luck. Martin
Paxar Monarch... • Answered on Aug 15, 2018
Check to see that you have the correct supply selected under "supply type". Are you running black mark supplies or die cut supplies? If the supply type selected doesn't match your actual supply type, you'll get a 704 error. It's also possible that the black supply sensor could be broken, or your platen roller (large black roller) needs to be cleaned. Clean it with alcohol.
Paxar Monarch... • Answered on Mar 21, 2016
Portion of field off supply or there may be invalid character in the format.
Paxar Monarch... • Answered on Dec 02, 2014
save as your fromat with new name and then send to printer
Paxar Monarch... • Answered on Jan 07, 2013
I haven't worked on Paxar products, but the manual directions seem reasonably complete, with drawings. (PDF pages 17-22 provide the basic directions; the following pages give directions for special media types and options.)Error #756 = "Load Supplies"I deduce from this that somehow you missed the paper detector when you loaded the supply strip. This is probably the "die cut sensor" referenced on page 2.3 (PDF page 19, shown in drawing on the next page). Make sure the strip feeds through the detector slot.
Paxar Monarch... • Answered on Nov 28, 2011
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Paxar Monarch... • Answered on Oct 31, 2011
Your main board needs to be replaced. You can't clear a 762 battery error...
There is a small shaft on the back panel of the printer, below the red/white dip switch settings. This shaft sas a slot in it. Facing the rear of the printer, turn this shaft clockwise to increase contrast. Press PAUSE and FEED buttons on front panel AT SAME TIME to print two label test labels. One of these labels will tell you your contrast setting. I wouldn't adjust the contrast any higher than about 75 (about half way) or you're in danger of prematurely blowing your printhead. Printheads are expensive...
Paxar Monarch 9825 Thermal Label Printer Logo
60 questions posted
Top Paxar Office Equipment & Supplies Experts
k24674
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
MONARCH Paxar
  • MONARCH Paxar
Most Popular Question
get parts monarch 1110 label
  • Office Equipment & Supplies
