20 Most Recent Kustom Profile 2 PA Speaker / Mixer Stand Questions & Answers
Kustom Kpm7250
Output transistor failed. arlingtonguitarshop-dot:com
5/2/2019 6:53:55 PM • Kustom Profile 2... • Answered on May 02, 2019
Bought a powered monitor as it said to do in the
You haven't mentioned what model and manufacturer the mixer is. I will have to guess and say that the monitor out on the board isn't providing signal to the powered monitor or the monitor out on your board is powered and is now damaged by plugging a powered monitor into it. Carefully reread your manual and determine if the monitor out on your mixer is powered or line level. Reread also and make sure that the signal you are monitoring is assigned to monitor out, levelled correctly etc. If you find that the monitor out is passive (line level) try hooking it up to an external power amp and speaker. A guitar amp will do for testing purposes. Start with a low input volume on the amp. Also make sure that if it is passive to use a shielded cable from monitor out to input. If your board has powered monitor outs you can use a speaker cable from monitor out to speaker input (non powered monitor speaker).
12/14/2010 12:49:41 PM • Kustom Profile 2... • Answered on Dec 14, 2010
Bought a powered monitor as it said to do even
You didn't mention what brand powered mixer you have, HOWEVER MOST powered mixers also have a line level monitor and main output jacks. These are almost always 1/4 inch jacks. In any case you should be using BALANCED lines to the powered speakers using either XLR or TRS connectors on the ends. Please tell us what powered mixer you have so we can give you better answer regarding which connections to use. IF for some reason your mixer does NOT have line level outputs, you can use a high level Direct Box to condition the powered outputs to be sent to the powered speakers..
Also make sure ALL your interconnected equipment is powered by the same receptacle or source to avoid damaging due to ground bounce on utility lines and circuits. This often means running an extension cord from the stage where the powered speakers are along with a snake of the audio cables.
12/10/2010 7:32:26 PM • Kustom Profile 2... • Answered on Dec 10, 2010
2answers
Hello. Where is the fuse located to be replaced in my Kustom KPM4060 Amp. Thanks Shawn.
I have the same problem with my KPM 4080 amp. I have no clue where the fuse goes. I'm sure mine also needs a fuse replaced.
3/24/2020 10:08:50 PM • Kustom Music • Answered on Mar 24, 2020
Guitar amp? whining noise regardless of connections or volume settings?
Several possibilities (i have experienced all):
  1. 120V.AC line noise. Try moving to a new receptacle in a different room or breaker. Try a In line AC filter (like a Furman power filter/conditioner)
  2. RF interference. Plug in a different core and guitar to isolate.
  3. Guitar wiring. Bad ground internally or pot (volume) became ungrounded.
  4. Defective amp preamp section. Pot or transistor.
5/2/2019 6:44:02 PM • Kustom Music • Answered on May 02, 2019
2answers
The fuse in my Kustom Sienna guitar amplifier blows instantly on switch on. Any suggestions?
yes, take it back to the store and ask them why it is blowing fuses at power-on.
5/5/2018 3:55:13 AM • Kustom Music • Answered on May 05, 2018
I was just given a Kustom Sienna 65 Amp and it powers up but no sound coming out of speaker. I plugged a line from the ext speaker 1/4" out into a practice amp and got sound through the practice amp.
You may have a blown voice coil in the speaker. Can you see the back of the speaker? Then, First Check the connections to the speaker and make sure they are well connected. If they are, then the speaker is probably at fault. If you are handy, then you can get a replacement speaker, 12 inch?, and swap it out.
1/10/2018 5:49:41 PM • Kustom Music • Answered on Jan 10, 2018
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay There are 2 small switches which assign each Power Amp to either Monitor or Main Output. It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers. Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy. Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html and keep it with the mixer. ( Of course don't send speaker outputs to other amps or powered speakers )
9/20/2017 9:35:38 PM • Kustom Music • Answered on Sep 20, 2017
Kustom seinna 16 amp. reverb quit working. is their a fuse
Not separately on the reverb circuit. Timee to take it to the shop.
3/3/2017 2:24:48 AM • Kustom Music • Answered on Mar 03, 2017
0answers
0answers
0answers
Kustom Profile 2 PA Speaker / Mixer Stand Logo
5 questions posted
Top Kustom Music Experts
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Tom Chichester
Are you a Kustom Music Expert? Answer questions, earn points and help others
View Most Popular
Kustom Music
  • Kustom Music
Most Popular Question
kustom kpm7250
  • Music
