20 Most Recent Vestax Typhoon USB DJ MIDI Controller with Bundled Traktor Software. Questions & Answers
look at the back of your deck there shold be two little nobs that say touch sensor level turn it down to min or at least dont have them all the way up
Vestax Typhoon... | Answered on Aug 02, 2013
need to make midi controler your default sound player.
Vestax Typhoon... | Answered on Feb 17, 2011
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Vestax Typhoon... | Answered on Feb 12, 2011
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
Vestax Typhoon... | Answered on Jan 05, 2011
Hi, can you tell me if anyone has helped you with this problem yet? I am currently researching a similar problem and will load your software to see if I can help you.
Vestax Typhoon... | Answered on Dec 27, 2010
Check with Vestax customer support for a download.
Vestax Music | Answered on Jan 04, 2019
make shure the cable youre using between the the itch ( great little controller ) and the receiver is not balanced. here are the two options that will work. from your sure unit. xlr-to 1/4ts or 1/4ts to 1/4ts. there are two kinds of 1/4 inch connectors. these you know look like the standard guitar plug or some people call them phono plug. on the end of the prong you will see one or two rings. one ring means its tip and sleeve . two rings means your cable is tip , ring, and sleeve.
how is that software compared to the normal SL software?
i use, tech 1200s and a rane ttm54. but i dont use serato. i use torq. i love it.
Vestax Music | Answered on Apr 19, 2015
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Music | Answered on Nov 25, 2020
Contact Clavinova directly to request the manual.
Music | Answered on Nov 11, 2020
Did you get it fixed?
I have exactly the same problem!
Music | Answered on Oct 26, 2020
hi becky
from looking up the model some of the prices were only 30.00 to 40.00 dollars needing repairs other units/ models went higher in price depending on model and if they where in good repair.
so the decision for u would be is this the organ that you want to restore or do you want to look for other units?
Music | Answered on Oct 23, 2020
So I got a used one of these for free because it had the same issue.
I read about battery failure, so I opened up the piano and sure enough the battery had corroded. I also read that the battery is only necessary for the memory feature, which I don’t care too much about. I pulled out the board (super easy to do, no screws or anything, it just pops out) and took it a local electronics/tv repair guy. In about a half hour he took off the battery, fixed a bad trace on the board with a quick solder, and handed it back. $40.
Plugged it back in, bam works like a charm.
As long as there wasn’t too much damage from corrosion, a repair guy should easily be able to do what I described.
I hope this solves your (and anyone else’s) problem!
Music | Answered on Oct 06, 2020
Take it to a music shop. They should be able give you help in finding a good place.
Music | Answered on Aug 01, 2020
https://www.alphapianostudio.com/
"Great teacher (Sandy) with lots of patient. Friendly and nice and also passionate till I have little time to rest my poor little hand. Learned for about a year plus and now can play more fluently and confidently. Price is acceptable and duration is just nice."
Music | Answered on Jun 20, 2020
Vestax Typhoon USB DJ MIDI Controller with Bundled Traktor Software. Logo
Popular Tags
14 questions posted
Top Vestax Music Experts
Marvin
Marvin
Are you a Vestax Music Expert? Answer questions, earn points and help others
View Most Popular
Vestax Music
  • Vestax Music
Most Popular Question
vestax typhoon controller jog wheel
  • Music
