20 Most Recent Printronix P5010 Matrix Printer Questions & Answers
Have you done an online search for the drivers you are looking for? Usually if you do that you will find the web site that contains the drivers you need to download to get the printer to work.
Printronix P5010... | Answered on Mar 23, 2012
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
Printronix P5010... | Answered on Jan 01, 2009
My P7005 displays PAP FD DRVR CIR error
Printronix... | Answered on Sep 15, 2019
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Printronix... | Answered on Nov 20, 2014
The shuttle is actually the print head.If turning machine off and then back on doesn't fix the problem then you will have to replace the shuttle.
Printronix... | Answered on Apr 26, 2014
This is usually due to a bad main board. Occationally you can reload the microcode to fix it but not normally. Get the part number off the main board as there are 2 kinds and they are not easy to intercahnge.
Printronix... | Answered on Dec 16, 2013
An ******* or unsupported
instruction was attempted
in the application
program.
1. Cycle Power. Run the print
job again. If the message
appears, load the latest
emulation software.
2. Cycle power. Run the print
appears, record the display
message and send it to your
next higher support facility.
Printronix... | Answered on Mar 21, 2019
Based on your error you could have a P7000 or a P8000, Either way it is normally the main logic, but there are 2 for each machine.
P7000 V5
PRINTRONIX 250299 001 HURRICANE V5 PPC P7000 New
P7000 V6
PRINTRONIX 253081 991 LOGIC PPC V6 P7000 EXCHANGE New
P8000 LS
P8000 HS
PRINTRONIX 257114 001 CONTROLLER BOARD P8000 New PRINTRONIX 256443 901 CONTROLLER SUBASSY LS 5 10 New
Printronix... | Answered on Feb 15, 2019
I'm guessing the carrier solvent for the ink has evaporated. (Ribbon is old and dried out - even the new one) In the past, i have sprayed WD40 on unspooled ribbons and rewound them to bring ribbons back to life but that can be messy with spotty results. Suggest you buy direct fro Printronix.....
Printronix... | Answered on Oct 01, 2017
Printronix P5010 Matrix Printer Logo
5 questions posted
Top Printronix Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Harrie
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Matrix Printronix
  • Matrix Printronix
Most Popular Question
double printing no giving proper
  • Office Equipment & Supplies
