20 Most Recent
Printronix Line Matrix P5210 Printer Questions & Answers
Printronix p5210 firmware
Hello Fadel,I emailed 2 different Emulation files...Let me know if you receive an error. If you get Flushing Ques after you started the download, then you don't have enough Dram memory, Flash memory or Security Pal chip needs a specific Emulation file.
Could you provide me the Windows 7 64bits for P5210?
There is not a windows 7 driver for the P5000, but the P7000 driver has been fully tested by Printronix to work with the P5000. Alternatively you can use the printer in Epson emulation mode and use the Epson 1080 driver included in Windows7.
Prints four blank pages between each printed document...
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Hi i wan to download
www.printcountry.com/drivers/PRINTRONIX_P5220_GOLD_SERIES_2000_DRIVER_DOWNLOAD.htm
driverscollection.com/?H=P5220&By=Printronix
http://driverscollection.com/?H=P5220&By=Printronix
http://www.printcountry.com/drivers/PRINTRONIX_P5220_GOLD_SERIES_2000_DRIVER_DOWNLOAD.htm
tyr anyone of these
Characters out of alignment
OFTEN the cause of alignment problem is that the paper tractors are too loose and paper moves more than it should. It takes careful adjustment of the tractors to hold paper just right when the hammers hit the characters. Too tight and the tractors tear out the edges, too loose and characters rattle around in alignment.
OTHER problems can be caused by TOO LOW humidity which causes electrostatic attraction and drag. SOMETIMES they use an ionizer bar and the high voltage power supply goes bad. Another thing is drag from the stack of paper source.
