20 Most Recent Proscan PS56670 56" Rear Projection Television Questions & Answers
Wont turn oin no picture makes a popping noise
Either a bad control board, burnt out bulb, or power board issue. Look into replacing them.
6/7/2015 11:36:17 PM • Proscan PS56670... • Answered on Jun 07, 2015
Tv talks but no picture
You have lost the high voltage section, or you are on the wrong input. Try change inputs while sound is on.
1/17/2011 8:36:06 PM • Proscan PS56670... • Answered on Jan 17, 2011
Original tv remote stopped working.
You must first check that the remotes are working or not. Code searching comes after that.
To check your remote (try the original one first) follow this guide at wikihow. Its easy but requires you to have a camera phone or digital camera.
And make sure the batteries are new and in correct position. Let me know the results.
6/25/2010 2:06:40 PM • Proscan PS56670... • Answered on Jun 25, 2010
2answers
Proscan ps56670
Power problem
7/28/2009 1:26:35 PM • Proscan PS56670... • Answered on Jul 28, 2009
I have proscan 56'projection tv when turn on only
check the video connection that is connected to the tv. If you are using RCA style plugs (red, white, and yellow) you can try swapping the colors around (put the red in the white, the yellow in the red, and the white in the yellow on the tv and your other device....cable box, vcr, dvd, etc.) this is a great way to test the cable you are using to send video to the tv. it might just be the cable!
7/11/2009 2:07:37 AM • Proscan PS56670... • Answered on Jul 11, 2009
Proscan PS56670 56" rear projection TV
For a 10 years old TV, it might not be worth fixing it. Save your money to get a new one once this one gives up.
I would keep it running using with the back cover off using that fan to keep it cool.
Hope this helps.
4/29/2008 5:07:31 PM • Proscan PS56670... • Answered on Apr 29, 2008
Convergence Problem w/Proscan PS56670
IN THAT CASE YOU NEED TO REPLACE THE CONVERGENCE STK'S AND SOME TV'S NEED A INTERNAL ADJUSMENT AFTER REPLACE THE CONVERGENCE.
1/18/2008 5:35:04 PM • Proscan PS56670... • Answered on Jan 18, 2008
Broken Screen
IF YOU CALL DIRECT TO THE COMPANY AND THEY DON'T HAVE IT. THE ONLY THING YOU CAN DO, CALL TO A TV REPAIR SHOP ASK IF THEY HAVE A USED SCREEN IN GOOD CONDITIONS, YOU NEED MESURE THE SIZE OF THE SCREEN UP/DOWN AND SIDE BY SIDE.
1/18/2008 5:32:45 PM • Proscan PS56670... • Answered on Jan 18, 2008
Blurry - Looks like 3d
THE PROBLEM IT'S THE CONVERGENCES STK.
1/18/2008 5:29:28 PM • Proscan PS56670... • Answered on Jan 18, 2008
Power on power off
IF YOU TV IT'S THIS MODEL # 60P8241 THE PROBLEM IS THE MODULE LOCATED NEXT TO THE TUNER ( SIZE ABOUT 2 1/2 INCH - 4 1/2 INCH). MODULE # 3139 123 5305.5
1/18/2008 5:27:57 PM • Proscan PS56670... • Answered on Jan 18, 2008
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
11/3/2007 1:45:20 AM • Proscan PS56670... • Answered on Nov 03, 2007
Can you program a universal remote for my ProScan digital box
It's doubtfull
9/25/2021 1:10:58 PM • Proscan... • Answered on Sep 25, 2021
How can I reset my 32 inch proscan tv
It should be in the menu, if you can't find it there go to proscan website for the information
8/15/2021 8:39:51 PM • Proscan... • Answered on Aug 15, 2021
3answers
Backlight problem on pled6090
Bad caps on power board
8/6/2021 5:55:50 PM • Proscan... • Answered on Aug 06, 2021
How to watch tv w mine I have.
ever think perhaps I need an outdoor antenna wifi is only good if your TV is a smart TV
6/18/2021 1:43:41 PM • Proscan... • Answered on Jun 18, 2021
How to reset proscan modle PLEDV2488A
Unplug it for 5 min's
5/14/2021 2:51:59 AM • Proscan... • Answered on May 14, 2021
Model pLDED5520uhd. Has sound. Why no picture?
check input or source if ok check audio see if speakers on
4/9/2021 4:29:31 AM • Proscan... • Answered on Apr 09, 2021
Televison & Video Logo
20 questions posted
Top Proscan Televison & Video Experts
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
proscan 56projection tv when turn only
  • Televison & Video
