20 Most Recent
Memory Navi Honda Genuine OP VXM-090CV Questions & Answers
I replaced the battery of my honda airwave 2007
I'm not familiar with your market area's vehicles, but in North America there was an issue with Honda's navigation systems causing damage to the discs. Remove the disc and inspect it for circular/crescent shaped grooves or scuff marks. If you find this type of damage you need to replaced the audio/navigation unit.
How do I change the time on my audio system as the instructions are in Japanese.
Gathers Memory Navi Honda Genuine OP VXM-090CV... seems to resolve to a NENGUN Company.
Babble-Fish Time:
Funny... A global community... we are not hardly ready to cope with
(fear not... I'm sure there's an "APP" for that (APP being the FROSTING for the cake you don't have (or want))).
Well... My first inclination was to learn Japanese... but I'm old (not enough road nor time & too many other interesting things)
Astoundingly:
The following "comforting" statement ... on the CORPORATE HELP WEBSITE (http://www.nengun.com/help/website.)... says:
Even if you can't read Japanese, it is preferable to see the actual Japanese characters than invalid characters, often shown as black boxes.
I COULD not disagree... Black Boxes or Japanese are pretty much the same to me (Perhaps the Japanese "MENU" icon ... is flashing green).
And then...
If you are using Microsoft Windows this can be "easily" fixed by downloading and installing the free Japanese Language pack from Microsoft.
Hubris:
Hopefully this "EASY" stuff on their website... comforts you better in ENGLISH.
Good luck with that.
Go to...
Japanese Language pack from Microsoft:
See bottom, goes all the way back to XP
https://www.babelfish.com/tag/japanese
http://www.nengun.com/gathers/memory-navi-honda-genuine-op-vxm-090cv-298305
We couldn find the page
Help
Language packs Microsoft Windows
So in Japan car you never adjust time ?
Most cars since 2000 do not have a distributor that can be turned to adjust the ignition timing. The signal comes from a crankshaft sensor to the ECM which uses that as a reference point of, for example, TDC or top dead center and fires the spark plugs at some point depending on RPM, load, temperature etc. There are exceptions, but most are PCM (powertrain control module) computer controlled. Some aftermarkets make chips or performance tuning to change the timing. They also make exaggerated claims.
How to change time in Gathers VXM-128C ?
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with
the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
- Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
- Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
- Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
- Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
- Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
- Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
