20 Most Recent Olympus m:robe MR-100 Digital Media Player Questions & Answers
Did you go to Olympus's m:robe site and download the firmware and install it again?
Olympus m:robe... | Answered on Feb 19, 2019
fatal system error
service required/004
Olympus m:robe... | Answered on Sep 05, 2011
on the bottom of your device their is a small hole you will need to find a paperclip or something small and push into that and hold it down to make it reset.
Olympus m:robe... | Answered on Jun 08, 2011
Please reset the player, use the reset key to set the player.
Olympus m:robe... | Answered on May 14, 2011
hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Olympus m:robe... | Answered on Mar 04, 2011
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Olympus m:robe... | Answered on Feb 11, 2010
try to update the firmaware and then format it with the help of tht..!!
just smile.... its ok :)
Olympus m:robe... | Answered on Feb 09, 2010
if it is a hardware complain its better to give for service else try this method
try to update the firmware and reinstall m:trip software..!!
okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index extract the files to your player and then
after tht install the firmware http://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..before installing the firmware make sure tht u reset the player ..after following all the instructions of the firmware try to synch the player to check whether it detects music and finally restart your m:robe to take effect..!!
i think the problem is with the harddrive and better try to change the wire which has got a link to the board..!!
there is a software named m:trip and i guess ull be having an installation cd of tht when u purchase the music player.else download it from
and after installing the software ,open the wizard(m:trip) in a small window and drag music to it .After dragging all the music,at the bottom right u may notice something called"synch"press that.. ..after synching u will be able to listen music from yo m:robe player..!!
Remove all the files. Then download all the files from :-
Once you unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset. I couldn't get the "invalid/missing file" screen to go away for a while.if you slide the hold button into the hold position and then push thelittle reset button on the bottom, it will remain off and you can putit on the dock, then it will connect to the PC.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Olympus m:robe... | Answered on Oct 06, 2009
Olympus m:robe MR-100 Digital Media Player Logo
56 questions posted
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
fatal system error service required 004
  • Audio Players & Recorders
