20 Most Recent
Dome (8) Cctv Dome Color Ccd Night Vision Vandal-proof Cams Questions & Answers
Dome camra wire connection with bnc
Preparation
Before installing your RCA camera scout the area and confirm that you will be able to run the cable from your surveillance digital video recorder (SDVR) to your camera. You may want to use RG59 Siamese cable, which is a single cable system with three wires: a coaxial cable for the video and a positive and negative wire to provide power to the camera. If you are installing your camera outside, place it at least 10 feet high to minimize tampering, or put your camera in a dome or other protective housing.
Coax Cable
BNC connector
BNC connectors and cable image by Albert Lozano from Fotolia.com
BNC connector
If you use Siamese cable to wire your RCA camera, you will run the cable first, and then install a BNC (bayonet Neill-Concelman--named for the inventors) connector on each end of the cable. BNC connectors vary by manufacture; install the BNC connectors according to the connector instructions. To get a general overview of the process, see the Resources section for a video on installing BNC connectors.
Power Wires
Plug with standard lamp-type cord
element electric power black image by Leonid Nyshko from Fotolia.com
Your camera came with a power supply with an integrated power wire; the power supply plugs into a standard wall outlet and the other end plugs into your camera. The cord is probably not long enough, in which case you will have to cut it and splice the Siamese in the middle to deliver power to your camera. The power supply wire is designed like a standard lamp cord and must be cut in half and split. One of the wires will be marked with a stripe, a series of dashes, a rib on the insulator or some other marking (just like a lamp cord). The marking indicates that this is the positive wire. After cutting the supply cord, connect the portion with the camera plug on it to the Siamese cable at your camera and then connect the power supply portion to the other end of the Siamese cable near your SDVR. The positive (marked) power supply wire should be connected to the red Siamese wire and the other wire connected to the black Siamese wire. While many people use wire nuts to connect the wires, connecting the wires with a wire beanie (see Resources) will provide a higher quality installation.
Plug-and-Play
Plug-and-play cables make it easier for homeowners to install their cameras. These cables incorporate all three wires into one cable system and come with connectors preinstalled so that you will not have to install connectors or cut wires. This is slightly more costly than assembling your own cable, but it will save you time and you will not have to purchase special tools to install the connectors. Run your plug-and-play cable and connect it by following the instructions which come with your cable. See the Resources section for a video on installing plug-and-play cables.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
