20 Most Recent Sierra International 18-5199 Marine Condenser for Johnson/Evinrude Outboard Motor () Questions & Answers
The model number is 10532
The serial number is 01749
Sierra... | Answered on Sep 11, 2016
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Sierra... | Answered on Feb 03, 2016
I have never seen anyone answer these questions.if you looking for a condenser they are all the same.eg a 1965 40hp condenser will fit a 1955 20hp
50/1. 1 pint to 5 gal
Sierra... | Answered on Oct 11, 2014
Check and clean carbs. If same problem persists rebuild or change full pump. Firstly ensure clean plugs,and fuel filter. If you hook up a inline fuel pressure gauge, then run. You may have low press output, at cont full load. If so you need to open your vapor separator tank. Check and clean high presure pump and pre filter. You need to clean and inspect needle and seat. Than repeat test as outlned above.
Sierra Boating | Answered on Sep 25, 2017
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Boating | Answered on Aug 29, 2020
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Boating | Answered on Aug 26, 2020
First, make sure that you are trying a lifejacket that fits your weight and height. The best way to test it is to work in a pair. Hold your hands straight above your head and have someone else pull up the tops of the arm openings. If the jacket covers your face or chin, it is too large.
Boating | Answered on Aug 25, 2020
It should be on the makers tag sewed onto the jacket
otherwise contact the manufacturer on the net
I think that google might have a manual for your 1996 35 doral SC. You can always try searching on google and type in the google search engine.
Boating | Answered on Aug 04, 2020
Only three ways
Connect a transducer or head unit from a friend.
Buy a new one.
Return it to the factory for testing.
Does your mystery fish finder have a demo mode? That _should_ prove if the head unit is olay.
Boating | Answered on Aug 03, 2020
Not sure if this link will help
https://www.bitchute.com/playlist/zdU7Ihae6i4C/
A little history on the glastex later sold as sea star and sea spirit
http://www.fiberglassics.com/library/index.php?title=Sea_Sprite
Boating | Answered on Jul 06, 2020
CHECK WITH THE MANUFACTURER IS ALL i can suggest as a fix NOT SOMETHING A DIYER HAS THE CAPACITIES TO DO
Boating | Answered on Jun 25, 2020
Sierra International 18-5199 Marine Condenser for Johnson/Evinrude Outboard Motor () Logo
5 questions posted
Top Sierra Boating Experts
Jeffrey Turcotte
Jeffrey Turcotte
Kardoc
Bill Boyd
Are you a Sierra Boating Expert? Answer questions, earn points and help others
View Most Popular
Sierra Boating
  • Sierra Boating
Most Popular Question
1503201749
  • Boating
